Thread: 86 200x fork swap?
    az
    2,044
    86 200x fork swap?
    before selling the frame and motor, I stripped the 86 200x for parts i thought might come in handy in the future.
    So does the triple tree and forks fit other trikes? ive got a complete running 84 200x and a project 85 350x. Im sure the set up wont fit the 185s. jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    444
    I think you can interchange the triples and put them onto most honda ATC models.
    The issue will be the steering stops.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    devore,ca
    1,056
    There is differences in forks and tripples across the line of ATC's. 200x and 250r are trailing axle, 350x is leading axle, different tube sizes, 3rd gen 250r's have rake built into the tripples, 1rst gen 250r's have ultra wide tripples and tiny fork tubes. I've seen people do some swaps here and there, but it jacks up the steering geometry on most of them.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    az
    2,044
    would the tubes work in a 1st Gen 200x? debating weather its worth hanging on to them or just let them go. ive got a 84 200x, if its a back up for it, ill keep the tubes. jim
    81 185s
    82 185s
    and a 72 ct70
    Arizona
    509
    The tubes themselves will fit. Second gen tubes are a little longer than the 1st gen. The left fork lower is the same for both 1st and 2nd gen. The right fork lower is different on the second gen.
