Results 1 to 10 of 10
Thread: 86 350X bearing carrier
    GeoD's Avatar
    GeoD is offline At The Back Of The Pack Arm chair racerFirst time rider
    Carbon County, PA
    178
    Hello folks! I am reviving my 86 350X from 14yrs of storage. All is going well and it's almost ready to ride for another 40 years! One thing I noticed is the rear is binding up and I can't easily push the trike around. I'm interested in a double row bearing carrier and wanted to know if anyone had any suggestions of a brand I should look to purchase. The rear has a DuraBlue HD extended axle.
    I bought one of the last 85 350X aluminum double row carriers back in 2007. I say this because I have not seen an 85 carrier available on eBay or Amazon lately. I believe it was a Lone Star carrier.
    I asked Gemini AI the question and the following are the results:
    For a 1986 Honda 350X running an extended DuraBlue HD axle, a billet aluminum carrier is the best choice over a factory cast unit because it won't flex or crack under the added leverage. Now that the engine is tuned and pulling cleanly without that mid-throttle bog, a heavy-duty twin-row setup will ensure the rear end can securely handle the torque.
    The Niche Rear Axle Bearing Carrier For Honda Atc350x 1986 is an excellent plug-and-play upgrade for your trike. It is machined from 6061 high-grade aluminum and comes pre-packed with double-wide heavy-duty bearings that easily outlast factory single-row bearings. It also includes a highly convenient center-mounted Zerk fitting so you can quickly pack it with grease without tearing down the rear end.
    Niche Rear Axle Bearing Carrier For Honda Atc350x 1986 $71.95Niche Industries 5.0 (2) Opens in a new window Another great option is the 1986 Honda ATC 350X Billet Axle ATV Bearing Carrier. This unit is heavily reinforced and machined from 6061-T6 aircraft-grade aluminum to exact OEM replacement specs. It arrives fully assembled with the double-wide bearings, central spacer, two new seals, and a grease fitting, making your installation quick and simple.
    1986 Honda ATC 350X TRX300EX 300EX Billet Axle ATV Bearing Carrier | United States $79.00Honda Opens in a new window Both of these billet carriers will slide in smoothly and pair perfectly with your aftermarket axle. If you like, I can pull together some heavy-duty swingarm bearing kits or chain and sprocket combinations to completely finish out your rear-end rebuild. Do you want me to do that?
    Geo D
    1+2=ME
    My Toyz
    Jun 2013
    Oceanside, CA.
    619
    Which sprocket assembly are you using on the DuraBlue axle, '85 using standard nut & bolt or the '86 with a countersunk bolt & nut?
    "HJ" Click image for larger version.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    GeoD's Avatar
    Carbon County, PA
    178
    I will have to get back to you when I can take a look at things. I'm gonna assume it will be the 86 countersunk bolt and nut.
    Geo D
    1+2=ME
    My Toyz
    GeoD's Avatar
    Carbon County, PA
    178
    I took a quick look at both my 85 and the 86 350X sprockets and they are both definitely different. I'm going to say the 86 has the counter sunk sprocket as you mentioned. I will post some pics later today when I get to the garage.
    85X
    86X
    Geo D
    1+2=ME
    My Toyz
    Jun 2013
    Oceanside, CA.
    619
    The '85 is correct. Now the '86 I need a picture of the opposite side (bearing side) but what I think I'm seeing is the DuraBlue axle used a pressed on hub flange and you bolt a sprocket to it, not countersunk bolts, that's why you need the "85 carrier. Expected to see something like another 3ww member "Shawn"s axle setup where he needed a spacer to line up to the countershaft sprocket.
ID:	272129 Click image for larger version.
    ’84 YT60
    ’90 LT500 Quadzilla
    GeoD's Avatar
    Carbon County, PA
    178
    I got a snapshot of the other side tonight.
Name:	86X Right Rear.jpg
    Geo D
    1+2=ME
    My Toyz
    Jun 2013
    Oceanside, CA.
    619
    Sorry the snapshop is too dark. Take another same angle only a close up of only the sprocket / flange area.
    ’84 YT60
    ’90 LT500 Quadzilla
    GeoD's Avatar
    Carbon County, PA
    178
    Here's a better view.
Name:	86X Right Side.jpg
    Geo D
    1+2=ME
    My Toyz
    Jun 2013
    Oceanside, CA.
    619
    As the sprocket mounting bolts are threaded an flush with the axle hub face I believe you can use a "86 carrier. Your carrier adjusting flange looks as thick as a stock carrier. You might need to make a minor machine cut to the seal face area on a new replacement carrier if too thick.
    ’84 YT60
    ’90 LT500 Quadzilla
    Feb 2017
    Corona CA
    861
    Hairy !!
    Hello. Nice you see you posting !
    My setup is a 86 style swinger with a 300ex carrier (compatible with 350x direst swap ) niche dual row , with a 300ex axle and sprocket , spacer made by Luis Milke , once sold at the 3ww store. Before I bought that i used 1/2” stainless spacers with many miles on them no issues. Spacer looks much nicer though , and is hub centric for the sprocket and carrier.
