Thread: Rim Size
    Dec 2002
    36
    Rim Size
    If you were to buy new rims, what size would you go with and why? I have seen that the 10" and 8" seem the most popular. Do they make more tires for one vs. another? Are there more rim choises for one size vs. the other?
    Fresno Ca
    2,695
    9's and 8's are the most common because thats what come on the hondas stock as far as picking a size of a rim i dono why you would go for one size over another other than looks
    200xer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    the bigger the rim the less a tire will roll over, so it'll be less likely to 2 wheel. I'd go the biggest wheel possible, which I think is 10" for most tires.
    85 200x - Torn apart
    Dec 2002
    36
    What is the bolt pattern for the front of a 250r? What size tire and rim do people usually run on the front of a 250r?
    02' Honda Rancer, 02' Honda Foreman, Working on a deal to pic up an 86' 250r ATC and a 98' 300ex frame set up for a 250r motor!! This will be my first trike, and it needs some work, but it will be BAD!!!
    Rittman, Ohio
    6,276
    There are obvious advtages to 8" and 9" rims, of having more tire between the rim and the road, which protects the rim and gives you a better, smoother ride. I asked somebody who was using big rims with a small tire what the point was, and he told me (which made sense) the purpose was to save weight. Aluminum rims weigh less than a lot of tire. He also confirmed my concerns that this setup is strictly for the track, and if you use it on rocky Ohio trails, your rim will soon look like a crumbled beer can. 200xer is right in that youll get less rollover, which is not wanted on a race track, but is somehwat desireable on the trails and can be adequately controlled with air pressure on trails to the extent that it needs to be.
    Nov 2001
    B.C.
    933
    If you wanted to go to a 10" wheel, but your pattern isn't available, there's enough material on the new wheels to drill a second pattern onto them, and even a 3rd! Just get the lug centers right!
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
