Results 1 to 15 of 27
Thread: still a few problems with the yt175 tri-moto
    May 2003
    Shediac, New Brunswick
    1,126
    Alright here it goes:
    There are 4 bolts holding the reed valves/intake on, well the guy before me broke the two top ones off. They are still broken but i just jb welded all that stuff to gether and used the two bottom bolts to hold it on.
    Now, if i start it in gear it will move a bit and if i give it gas it will drive abit or just stall. I can get it to drive sometimes if i am up and down on the throttle and rocking it back and forth. Now I think it is running way to lean, but I dont have a 13/16 socket to check the plug, i am buying that tomorrow. I am running with no airbox and no air fliter right now, do you think that would cause it too run lean?
    Any help will be great. Dont say I am an idiot for jb welding the intake on.
    '84 Honda 200x
    slow restro
    Ithaca, NY
    2,596
    OK, I wont say it, but someone else may..
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
    May 2003
    1,126
    i know i know, it was just a quick fix though, do you have a good way to get the bolts out of the cylinder?? they are basically flush.
    '84 Honda 200x
    slow restro
    May 2003
    140
    ytm175
    Don't ride it ,drill out the old bolt's and get a tap and rethread or take it to a shop and have them.A lean motor won't last long!!And will cost at least $125 US to fix.Where rethread will cost $20
    May 2003
    1,126
    yeah, another reason I know its running lean is cause it runs alot better with the choke on.
    The only thing is I am gonna have to take the cylinder off, is that a big deal ?? .. do I have to take the engine out of the frame? and one more how do I take the front sproket off, wont it turn the engine over? cause I think I am gonna have to take the engine out of the frame.
    '84 Honda 200x
    slow restro
    slippy4 is offline Just Too Addicted Arm chair racerJust too addicted
    May 2003
    556
    Yes, running it with no airbox on will cause it to run lean and run exactly like that. another thing could be compression, try to borrow one or buy one and test it. and to do top end work on it you dont have to take the motor out of the frame. to get the front sproket on you are supposed to have a sproket holder or a simple screwdriver or something along them lines will work to hold it still well you try to take it off. i would try to find someone with a different intake boot insted of trying to fix it, as it might be cheaper. you shouldnt have to take the cylinder off to fix it if you do try to go that way. however i am speaking as a trimoto 125 point of view but my understanding is that they are for the most part the same.
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    DG Pipe and Silencer
    Bored 1.25mm over
    Wiesco Pistion and Rings
    K&N Clamp on Filter
    Compleating Restoration
    May 2003
    1,126
    alright thanks for the help, its not that the intake is cracked its just that the intake bolts are broken off into the cylinder and there are only the 2 bottom ones holding it on now. I am going to put the air box on and try that out, if It dont work then I am going to try some silicon and then see how she works.
    Thanks, Chris
    '84 Honda 200x
    slow restro
    SE Minnesota
    533
    Quote Originally Posted by short4stuff
    Thanks, Chris
    lol, Leave the air box and silicone alone, and fix the real problem. Its the damn JB job on the reed cage. fix it or put a hole in your piston. You'll have too fix it properly sooner or later. Its much cheaper to fix it sooner.
    83 YT 175
    85 ALT 125
    May 2003
    1,126
    alright but whats the best way to get ther bolts out of the cylinder?
    '84 Honda 200x
    slow restro
    May 2003
    1,126
    look here is the problem now, i put it on blocks and put it in gear and it goes good shift all the way to 5th and it runs great.
    Now take it off the blocks and try to drive it yea right .... soon as you hit the gas it will just stall/bog out, I checked the plug and it looks good.
    ANyone?
    '84 Honda 200x
    slow restro
    May 2003
    556
    how much compression does it have? can you rev it out and then pop it in gear and move? try adjusting you fuel air mixture, but first make sure you have everything else solved (airbox on and intake fixed) To fix the intake try to get some ez outs or something of that nature. if you cant get it, i know a shop here that you can just take the whole thing in there and they will do it that way you dont have to take your cylinder off.
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    Bored 1.25mm over
    K&N Clamp on Filter
    May 2003
    1,126
    hmm ok for the bolts in the intake will i be able to do it with just a drill? and to use easy outs do you have to start to drill them out first?
    ALSO:
    I had it driving before, sometimes you can give it some gas and it will sometimes take off, most of the time just bog out. Yes I am pretty sure there is enough compression.
    '84 Honda 200x
    slow restro
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    sORRY ABOUT THE problems
    Wish i could help you out man.Sucks to be you.Wish the best of luck to you.If it aint broke then dont try to fix it.Then fix it all already.
    Edog was here
    Dec 2003
    4
    One way you can remove the bolts is to take a punch and sharpen it down to a point. Then with a small put the punch on the broken bolt and tap it til it turns out. I know its tedious, but I have removed many a broken bolt this way.
    Josh
    83 atc200
    83 tri moto 175
    May 2003
    1,126
    Quote Originally Posted by enlightend1
    Josh
    ok well have you done this to your 175 intake bolts?
    For easy outs do you have to start to drill into the bolt first and then use the easy out or?? ...
    But I dont think the intake is my problem I think it is something else, when the trike is not moving it runs great.
    '84 Honda 200x
    slow restro
