Results 1 to 15 of 20
Thread: The 4cyl Trikes
    The 4cyl Trikes
    What do you think guys of 4cyl trike...i want to fit a engine on my frame but i would like to have some opinions!!!
    1986 ATC bigred250es
    1985 ATC 350X
    1985 ATC 250SX (Sold)
    LT230S+RM250=quadracer 250 (Custom project)
    1997 MXZX 440
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    well its been done,,, basiclly a straight line machine ,,its tooo heavy to do much else!!!! kinda a novielty thing,,,,but thats all,,,, my brother built this several years ago,,,,, the only place it would beat my 250r is after i was at top speed then it would go by cause it was geared to go over 100,,,,,
    4cyl trike
    hey, not a problem, what do you need to know??
    one cylinder is not enough!!
    How time you put on it and how hard it was?
    1985 ATC 350X
    1997 MXZX 440
    4cyl trike
    hey, this one went pretty fast, because I had all the parts. we put it together in about a month, couple hours a day. depends if you use the bike frame, or the trike frame. use the wire harness off the bike. the quads took longer, to alter the frame, and re-engineer some other parts.
    Houston,Texas
    1,044
    hey 4 clyinders,did you use the bike frame and just put the front and rear end on ?
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    4cyl trike
    hey, kinda, but use the trike sub-frame for the seat, etc.
    I have a 600cc cbr engine and i put it into a atc 350X frame!!!
    I think that would be enough performant!
    1985 ATC 350X
    1997 MXZX 440
    Hey 4cylinders...What engine you have in your atv???
    1985 ATC 350X
    1997 MXZX 440
    4cyl trike
    hey, which one?? hehehe, all three are honda cb750's!!
    Very cool!!! in my 350X's ill put a CBR 600 liquid cooled engine...that will be more fitting than a free-air engine
    1985 ATC 350X
    1997 MXZX 440
    broook's Avatar
    broook is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2003
    Newfoundland
    207
    Should be a pic below of a trike with a Honda CBX 6 cylinder in it the same as my 1980 motorcycle.
    very nice trike broook, but what is your top speed? with this one?
    1985 ATC 350X
    1997 MXZX 440
    Quote Originally Posted by Trikemaker
    1985 ATC 350X
    1997 MXZX 440
    my engine is more look like this
    1985 ATC 350X
    1997 MXZX 440
