Thread: Tecate Jetting Help
    JMiller's Avatar
    JMiller is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Tecate Jetting Help
    My '84 T3 is running rich. It has an aftermarket pipe, 34mm carb, UNI pod air filter. The jetting is 180 main and 30 pilot. Does this sound right. What size jets should I try next?
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    cedar falls, IA
    546
    sounds to me like those jets are way too small. I have posted before that the stock jets are 230 and 45; are you sure you are running rich?? what are your symptoms? white smoke????(coolant) fouling plugs???(rich) sluggish off idle?(lean). I will double check my manual to be sure on the jetting but I think thats correct
    The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
    85 atc350x ('05 christmas present to myself)
    84 tecate (my baby)
    84 honda 110 (lil buddy)
    81 honda 70 (daughters ride)
    86 lt250r (sold for parts) R.I.P.
    JMiller's Avatar
    The jets are small, but wasn't the stok carb size on an '84 T3 32mm? I have a 34mm. Does that mean I need smaller jets? I dont know. It is sluuggish until I open up the throttle and it cleas up. The motor is like new. My plug is black.
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    cedar falls, IA
    546
    you are right the stock carb is a 32 but when you add more air you need more fuel. what kind of carb is it??? stock carb is a mikuni
    84 tecate (my baby)
    JMiller's Avatar
    Its a Mikuni. Its stock and is almost identical to the one on my '87. How can I tell for sure if its running rich? I have unburnt fuel coming out the exhaust. What should I do?
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    JMiller's Avatar
    Anybody have any tips?
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
