Results 1 to 15 of 18
Thread: best dune trike?
    Oswego, IL
    1,858
    best dune trike?
    what is the best trike or quad for the dunes. when i finish the x for the woods i want something for the dunes.
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Mar 2003
    Kansas
    1,507
    Something 2 stroke... Either 250R, Tri Z or T3..
    Oswego, IL
    1,858
    are 2 stroke a pain to work on? i like the 4 but i know i have to get a 2 for the dunes. my dad bro and uncle say dont get a 2 stroke they are high matience. is this true?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Newfoundland
    5,280
    I wouldn't call them high maintanence at all. Change the piston rings and sparkplug every now and then and the rest is so simple to work on.
    As for the dunes, anything 2 stroke is goin to be fun. I'd recommend a Banshee or any of the 250 2 stroke trikes(especially a TECATE!!!) :-P
    Jul 2003
    137
    they may be higher to maintaine?, but as far as working on a 2-stroke. in my opinion it does'nt get any easier. there's just nothing there, it's simple.
    85 200x
    86 cr 125r..(in peices)
    85 200x..project!
    I'd go with a 250r,Z or tecate...
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Newfoundland
    5,280
    Yeah...topend has the cylinder and head containing the piston/rings and connecting rod...four bolts to remove the whole topend assembly. The bottom end is the most complicated part of the entire bike...has the gears, crank,shift forks and kick-starter...there is very little to work on.
    You should get you a 350x, you can ride them in the dunes or the woods. a 250r is a little more fun on the sand though. here's a link on 2 strokes.
    http://science.howstuffworks.com/two-stroke.htm
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    ATC500R WITHOUT A DOUBT!!!!!!
    Mar 2003
    Kansas
    1,507
    It all depends on your machine. Some 4 strokes are a pain in the butt,... and Ive been around some that the guy is always fighting to keep running. Ive also been around 2 strokes that are a huge headache.
    Then again, Ive been around both 4 and 2 stroke trikes that run just like they rolled off the showroom floor in the mid 80's. Like they said above, 2 strokes are easy as hell to work on.
    4 strokes may be more reliable, but there is nothing, NOTHING in the world like a perfect running 2 stroke on the dunes,.. thats a hard experience to beat 8)
    Apr 2003
    Central New York
    1,860
    Dune mobile
    Buy mine because it should only be ridden in the dunes because its so pretty
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    Indiana
    458
    a 350x or a 250r would probably do pretty good on the dunes.
    Current rides:
    85 Honda 200x -- For Sale
    86 Honda 200x
    79 Honda Z50 minibike
    If speed kills......I'm a dead man!
    Oswego, IL
    1,858
    KASEY- wana build me a couuston atc500? do you got one? lets see some pics.
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    Dec 2002
    749
    Id say any of the high performance 2 stroke trikes. Like these guys allready said working on the engine doesnt get to much easier. Not sure about the other 2 stroke trikes but on the T3 its great being able to do a top end rebuild with the engine still in the frame.
    3WheelsForever / Virgil
    TrikeFest 03, 04, 05, 06, 07
    1985 Honda ATC350X - TF2015 Project
    YZ426 Hybrid Trike - On the back burner
    Oswego, IL
    1,858
    well if you got some totaly tricked dune trike let me see them im think a T3 or a tri-z. just got to decide between the two now.
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
