Results 1 to 14 of 14
Thread: Another great deal!!!
    jdparsons1's Avatar
    jdparsons1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    Toledo, OH
    360
    Well, so far any way. Picked up this 85 ATC 110 for $100. Its been sitting under a canopy outside a barn for a few years. Brought it home and put a new plug in and tested spark and got spark. Did a compression test and had 140lbs compression with the engine cold, so i changed the oil and pulled the carb off and cleaned it real good and wha-la. Started right up and purrs like a kitten.
    Now for the problem. The shifting on it seems weird, doesn't seem to matter whether im in LOW or HIGH on the tranny. I can be in neural and shift down and it does nothing but if i shift up it will go into gear. and it doesn't seem like it goes through all 4 gears but i could be wrong. I haven't driven it much because i don't have the air boot for the carb and its kind of sucking too much air right now and wants to stall. If i remember correctly the 110 is supposed to be 4 down, correct?
    Anyways, im hoping to get this running for my oldest son, if not im sure i can always get at least double what i got in it so far. If i do get it working right Im going to put a new seat cover and tool box cover and was thinking about finding an aftermarket pipe for it to make it sound better.
    Houston,Texas
    1,044
    My 110 won't go through all gears sitting either.When I ride it it shifts fine, nothing to worry about. The 85's are 4 up.Looks like you got a good deal. My 110 lost spark yesterday. :evil: :x
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Mar 2003
    Kansas
    1,507
    nice find!! cant beat that kinda deal!
    eh_tee_see's Avatar
    eh_tee_see is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Bristol Bay Alaska
    295
    hey hondatrikesrule22, i think i know what your problem is. take your cdi cover off and see if your pulser can be rotated freely just by hand, if it does this or even if it doesnt, remove your pulser and the thing that the pulser connects to (you will have to screw up the timing to do this but just use a permanent marker to keep it aligned) there should be a little pin sticking out of the camshaft, thats the thing that the pulser clings to.if it is, then i just wasted your time, but if it isnt, go get any 90,110,125,185,200 camshaft (cept an x) and take the pin from it. this has happened to me on both my 110s and my 185 and 200 shees.. hope that helps
    The below sentence is TRUE.
    The above sentence is FALSE
    Indiana
    458
    cool find. thats a really nice z50 you got there in the backround. i've got one almost exacally like it.
    Current rides:
    85 Honda 200x -- For Sale
    86 Honda 200x
    79 Honda Z50 minibike
    If speed kills......I'm a dead man!
    Nice find,those trikes are pretty simple to work on.
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Mar 2003
    Barnesville,Ohio
    2,298
    100 dollars was a hell of a deal. hope you get it runnin good.
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    jdparsons1's Avatar
    Dec 2002
    Toledo, OH
    360
    It runs awesome. Starts right up and there is no ticking or rattling from the motor at all like i've seen on alot of the older 90 and 110's
    May 2002
    Dublin, Georgia
    635
    Think on this
    Are you sure you are in neutral. If it doesn't feel like it goes thru all the gears you may be in 3rd(trashed gear) and believe it is in neutral. That would give the impression of having to shift up to get a gear. I would continue to shift up to see if you find neutral. Neutral should be all the way up, fourth all the way down.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    jdparsons1's Avatar
    Dec 2002
    Toledo, OH
    360
    No. it appears that "Hondatrikesrule" is right about it being 4 up on the 1985 model. Weird they did that for the last year of the 110. I drove it up and down the street throught all 4 gears in high and low. I had a couple times where i had it in first and stopped and it seemed to slip back into neutral, but never while driving.
    On another note,,, i just used that KREME stuff tonight on the gas tank and i cant believe how good it takes the rust out of the tank!!!
    Mar 2003
    472
    Quote Originally Posted by CHAINSAW
    i can!,lol,i got a 85 ytm200 in good shape for $75 from a complete stranger a couple yrs ago
    1985 Tecate restoration project-R.I.P
    Jun 2003
    20
    i got my 185s for 50 bucks minus rear brake drum and bearings and it ran mint till i started driving it now i have all kinds of problems. can you possible put the dual range thing on a 185 that would be cool to have super low gears for mudding.
    i have a
    1982 honda atc 185s with upgrade
    1980's kawasaki klt200 (broken forever)
    1982 hont atc 110 not running
    kdagenais is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    254
    I was pretty impressed with the cleaning portion of the Kreme kit myself but the coating process on the other hand was very time consuming. In a further note It has been almost a year on the 250SX that I used it on and no rust in the carb still. I still like to try the radiator shop theory if I can find you around me that will do it. Anyways you diffently got a good deal on the trike and I am sure there are plenty more out there just like that and hopefully I will find some for myself.
    Good Luck[/quote]
    Sheeez id like to find a deal like that for 100 bucks good find
    1983 Honda 110
    1967 Mustang
