Results 1 to 13 of 13
Thread: Stiching Fenders
    junjun01 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    290
    Stiching Fenders
    Any Suggestions On How To Stitch Or Repair Crack Fenders?
    Washingtons Crossing, Pa.
    2,977
    Yeah, buy new ones (unless they're not available). I really don't mean to be a prick either - I just think it makes your bike look like crap.
    Aug 2003
    290
    You Right...I Just Find Out That They Are Not That Expensive New.
    Just 115 From Factory
    Jan 2004
    Strongstown, Pa
    548
    Well you could drill a hole on each side of the crack then put a zip tie in the holes not sure how far i would space them out maybe about a inch or so.
    ____________
    83 250r (needs shock that works)
    Nov 2001
    B.C.
    933
    Drill 1/8th inch holes every 1/2 inch along the crack, about a 1/4 inch from the crack itself. Use small NYLON (not the cheapo dollar store plastic ones) zipties to fasten it all together. Remember to put the buckle on the underside of the fender.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Jul 2003
    936
    and if you can, get them to sorta match, if not white ones look ok...
    Wanna race? ;-)
    85' Tecate (still looking for entire front brake asembly...)
    bonanza mini-bike
    if you cant ride with the big boys...put it back on the trailer
    SE Minnesota
    533
    stitching fenders
    Use 14lb monofilament fishing line. They even make in RED now.
    83 YT 175
    85 ALT 125
    Tionesta, PA
    5,747
    I use stainless steel 18 guage wire and sinch it (twist) on the underside. It never breaks, rusts or comes undone. Plus it's shiney. Gives that "Frankenstein" look though.
    Indiana
    192
    and if its really weak, you can put a piece of plumbers tape on the bottom side to give it some more support. drill your holes to match the holes in the strip. just remember that this is a "patch", not really a good alternative to new plastic.
    Tim is the name
    85 350X(86 motor)
    83 200X(stripped down for a total rebuild)
    85 200S(project)
    Aug 2003
    290
    Done!!!!.......I Put holes using a electric solder,Then then use zip ties
    Watertown, New York 13601
    3,382
    Quote Originally Posted by junjun01
    Does it look like sh*t?
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Aug 2003
    290
    Nope...i put small holes & i use small zip ties, Tied UNDER, No on the top.
    looks good & i think it will last
    Moncton Newbrunswick,Canada
    509
    hay wire works
