Results 1 to 15 of 18
Thread: Oil in the gas
    Dec 2003
    59
    Oil in the gas
    The three wheeler I just bought ('83 big red 200), the guy who had it before me said that in every tank of gas he would put about a ¾ cup of oil in the tank. He thought it was good for them motors. Could this have harmed anything in the motor, such as a high carbon biuldup on the valves or piston? What do you think?
    1983 Honda Big Red 200E
    1985 Honda Big Red 250 ES
    1985 TRX 125
    1985 Citation LS electro
    Hunter
    Trapper
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Doesn't sound good
    If it's a two stroker,than it's fine.I spose a little the first time is all right but repeated applications mite be harmfull.I would just run 93 octane in it all the time if i were you.Oil can also gum up the carbarator.Get in the jets and other places it shouldn't :shock:
    Dec 2003
    59
    It's a 4-stroke, and I have already cleaned out the carb
    1985 TRX 125
    Hunter
    Trapper
    JoeSuzuki's Avatar
    JoeSuzuki is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Ontario Canada
    172
    Not too good to run oil in the gas of a four stroke, so if i was you....if it still runs fine....i wouldnt clean anything(dont fix it if it aint broke!), but i would run supreme with a bottle of fuel treatment for a tank or 2.
    Still learning how to use and abuse my toys.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Hello
    Yes i new this.
    JoeSuzuki's Avatar
    Jan 2004
    Ontario Canada
    172
    Well then you could always take off the exhaust and with a aircompressor blow air inside backward to remove carbon buildups.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Ha Ha
    It would take alot more than compressed air to get off carbon.You could get residu off buy useing air, but anthing that's been there for a while i dought it.
    Dec 2003
    59
    I noticed that in it takes a while to get up to speed, the machine feels sluggish, might just be me, haven't driven any other to compare. Feels ALOT sluggisher than my Big Red 250ES
    1985 TRX 125
    Hunter
    Trapper
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Maybe
    The float is sticking.Have you tryed checking that.
    JoeSuzuki's Avatar
    Jan 2004
    Ontario Canada
    172
    Why u asking for advice if your gonna comment every advice u get????? Just knock it a couple of time and then blow air backwards. The carbon buildsup will break in scale pattern and with a couple of knocks its gonna loosen up, and with the air some of it will be remove. You can always cook it on a barbQ but you have to be carefull with that one.
    Apr 2003
    Central New York
    1,864
    I had Carbon build up in my truck
    It was my father in laws and he drives Tractor Trailer and he drives slow. They call him the turtle. He only drove this truck to work and at the end of the week home. My truck was sluggish like that then I went on a long trip on the highway and after 2 hours of speeding it was smokin and crap then whalla it just stopped smokin and started rippin. Seems it just needed to be driven hard and fast to burn out all the gunk.
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Put another Carb on the barbi ,mate
    I'd love to see that ha ha Ya you should use a lighter to get rid of the extra fuel in the gas tank.That's the best way to do it Right!
    Rittman, Ohio
    6,276
    Re: Oil in the gas
    Quote Originally Posted by hondajas
    It wont really harm anything, but there is no benefit to him having done that. Its similar to running low rgas oil ratios in a 2 stroke. It may cause carbon to build up faster than normal, and may cause exhaust deposits to accumulate faster, and silencer paking to saturate faster. Start running regular gas, and dont worry about it. Most of the added deposits if there are any will begin to burn off anyways. There is no need to flush anything out or disassembler and clean anything unless after running a few tanks of normal gas, you still have excess smoke that just wont go away. Then you may have to replace packing material in the exhaust.
    Washingtons Crossing, Pa.
    2,977
    Tim, you don't think that extra 30wt oil might hurt his valve seats?.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Ha ha
    Don't you do it.Don't Make me take that away from you.
