Results 1 to 14 of 14
Thread: How do I adjust the timing chain?
    Dec 2003
    59
    In my Honda owners manual, it says to adjust the timing chain, just loosen a nut found on the crankcase while the engine is running, then tighten it. It will then be set. I did it but absolutely nothing has changed, my top end of the motor still ticks. Am I doing something wrong, or maybe the tensioner is passed it's prime, (doesn't work anymore)
    1983 Honda Big Red 200E
    1985 Honda Big Red 250 ES
    1985 TRX 125
    1985 Citation LS electro
    Hunter
    Trapper
    JoeSuzuki's Avatar
    JoeSuzuki is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Ontario Canada
    172
    does it still runs?????
    Still learning how to use and abuse my toys.
    Dec 2003
    59
    yep, runs perfectly, exept that ticking sound from the head, I really want to know what that is!
    1985 TRX 125
    Hunter
    Trapper
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    JoeSuzuki's Avatar
    Jan 2004
    Ontario Canada
    172
    If it aint broke, dont fix it!
    JoeSuzuki's Avatar
    Jan 2004
    Ontario Canada
    172
    Ask around maybe those trikes all have that same tiking,,,,like 84 bigred all have a grinding noise when you shut them off.
    almac16 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Halifax, Nova Scotia, Canada
    226
    it's likely the valves ticking. Try adjusting those!
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    It isn't broke
    It sound like the valve seating could be incorrect.Or worn valve springs,Or worn valves
    Jan 2004
    226
    check out:
    http://www.3wheeler.org/dirtwheels/6-87~tuneupindex.html
    it talks about adjusted the valves and cam chain
    Dec 2003
    59
    I adjusted the valves to .002'', and it still ticks. Currently I'm taking a power mechanics course from the school (it's free!) for the next 6 months. I'll probably bring in my ATC to rebuild it, cause the shop is VERY equiped, you can fix ANYTHING! What bugged mw was that another guy in that class brought in a 200 like mine and there was absolutely no ticking whatsoever, even with your ear right against the head. I want mine to sound like that, cause I need to rely on mine when out moose hunting many miles away!
    1985 TRX 125
    Hunter
    Trapper
    Jan 2004
    Strongstown, Pa
    548
    Quote Originally Posted by JoeSuzuki
    I dont' no whats wrong with your 84 bigred but mine don't make no grinding noise when i turn it off...
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Don't ride anymore
    That is until you fix it.It could end up costing you in the long run.Get it checked out.
    JoeSuzuki's Avatar
    Jan 2004
    Ontario Canada
    172
    There was a thread a long time ago about that chain running noise on BigRed when they get shut off and many more people have the same thing. Its related to the starter hookups. And there is no damage or whatever occuring by this.
    Howdy's Avatar
    Celina, Ohio
    10,079
    hondajas, The problem your having ( Ticking ) could be caused by a worn out timing chain. Once they stretch so far there is not way to adjust them.
    Howdy
