hey guys i need to know or have a good idea of the jetting specs i should have done to my carb for my tri z 250....
it has boysen power reeds, and a K&N air filter other then that its pretty much all stock.... im going to be bringing it soem ware to have the jetting done on it if i cant figure it out on the net, right now it runs pretty well but only with the choke on so there is def some things that need to be changed on it because id like it to run right with the choke off... and i herd there are alot of little things that need to be changed to make this carb work on my bike.... i know there are other peeps on here with the same carb on the tri z so help me out if you can please.
