Thread: 85 Tri Z Rear Wheels
    Dec 2002
    5
    My 85 Tri Z has 3 lugs on the rear wheels. Does anyone know if the 4 lug hubs from the 86 will fit my axels? Wheels are more common with the 4 lug pattern.
    Thanks, Robic
    asc180's Avatar
    asc180 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    Howard City, MI
    209
    Your Z Actually came with a 4/100 lug pattern so you can easily switch them.
    Adam
    Rittman, Ohio
    6,276
    I cant even figure out what 3 lug hub they managed to get on that thing! 85, 86 TriZ as well as all years of the Blaster are the same. Banshee hubs will also fit but have a different bolt pattern than the TriZ/Blaster so you have to use Banshee rims with them, but since youll be changing rims anyways Id go with what you can find.
    Dec 2002
    5
    Thanks for the input. I'll pick up a set of hubs and will have more options with my tires and wheels.
    Robic
    Rittman, Ohio
    6,276
    They sell the hubs on Ebay all the time. Stock ones go for about $15 is all.
