i got a 85 200x and it looks like i got to remove the whole front tire to get off the caliper. is there any secret?
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
Loosen all four lug nuts for the wheel and you can tilt the wheel far enough to remove caliper without removing wheel.
84 ATC200X--Wife rode it once, now I can't get it back.
84 ATC250R--Trying to find piston for 300R kit.![]()
85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
Remove the two bolts for the caliper, loosen the 3 nuts for the disk, and there should be enough room to slip the caliper by the rim.
