Thread: 85' - 87' 250es changes
    Mar 2003
    Australia
    1,919
    Hey all,
    Does anyone know any changes that occured from 85 - 87 on the atc250es? Apart from the graphics. Any engine diffrences, carb etc?
    Thanks,
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Re: 85' - 87' 250es changes
    Quote Originally Posted by atcmatt
    Hey all,
    Thanks,
    Matt
    Not sure about the ES but for the SX....
    87 motor had a cam chain tensioner change and the changes Jeswinehart mentioned.
    Carb is the Keihin 08 or best SX or ES carb to date.
    87 got different swingarms and enclosed rear brakes, better sealing orings on the axle tubes.
    Mar 2003
    Australia
    1,919
    Im asking out of general intrest. Dirtcrasher, when you say diffrent swingarm do you mean completely diffrent design?
    Thanks,
    Matt
    broook's Avatar
    broook is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2003
    Newfoundland
    207
    swingarm on the 86 250es can be removed. Carb had the cold start system added on the 86. rear axel bearings were sealed better. There were three different starter motors. At least two different sets of starter gears. Slightly different wireing harness. Different cam chain tensioner on the 87. i know for sure there was something else but just can`t think of it right now. :?
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    On the sx, the swinger is a lot different. The 85 hat the axle tube welded on,and the 86 has it bolted on
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Tionesta, PA
    5,747
    Between 85 and 86 there are a ton of differences. Control switches are diff. Swingarm is a completely new design for 86. Rear hubs are diff. Rear brakes got an update too - much better seal design.
