Results 1 to 15 of 27
Thread: cr125 into a 200x????? need pics!!!!!!
    Oswego, IL
    1,858
    will a cr 125 bolt into a 85 200x frame.will it be fasster and better then the 200x motor? anyone got pics of this? thanks in advance.
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    mart is offline *CERTIFIED* Mad Scientist Arm chair racerAt the back of the pack
    Apr 2003
    newcastle australia
    271
    gday mate yes im sure you can fit a cr125 in an 85 frame.my old boy and uncle did this to 2 83 200x's back in the 80's when they raced.we have a few old videos of them racing they were in the 200x class and they left the 200x's for dead,my uncle even said sometimes he would run his in the 250 class and usually come in around 3rd to 4th position so yes it is worth doing 4sure. later mate oh yeah and on that same video its got 1 of the court cases that were held over the banning of three wheelers.its got a guy from the cpsc telling the judge how many people the trikes have injured and killed since they came out. wink
    Oswego, IL
    1,858
    did the motor bolt in?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    May 2003
    Shediac, New Brunswick
    1,126
    I can tell you that its not going to bolt in, you will need to build some motor mounts to fit. Also I think the biggest thing would be fitting the pipe in there, I am sure it would be pretty good though, I own a yt175 and personally I would just rather have a 4 stroke, It dont seem to have the power that I want.
    '84 Honda 200x
    slow restro
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    I was going to do that transplant,but fell into other things. That would be a killer trike. Light and quick!
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
    Oswego, IL
    1,858
    anyone got any other information on this swap?
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    HaggLE is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Newcastle, Australia
    330
    I am the son of the uncle that Mart is talking about.
    I know this post was from a while ago but who cares, its a good topic...
    I spoke to dad about it and he says that it wasnt too hard. You have to cut the whole front down tube out and remanufacture it further forward. This is to allow for the pipe. The radiator is easy, just mount it to one side. But you will definately not going to fit any off the shelf pipes to the trike without modification. The top back mount is pretty much in the right spot, just line the chain up and modify the bracket. The easiest way to line the chain up is measure from the centre of the case to the sprocket on the 200x motpr and then the same for the cr125 motor. Do the mathamatics and move the motor accordingly.
    Should end up with the worlds best trike.
    Good luck if you are still considering doing it.
    Mar 2004
    North Central Ohio!!
    2,712
    Here's a couple pictures I found while browsing the web one day.
    I would like to do this someday too. I think a nice 86 roller would be great for a newer 125 engine.
    Attached Thumbnails Attached Thumbnails 2 Stroke 200X.jpg   2 Stroke 200x 2.jpg
    Delaware
    134
    Since we are on this subject...had anybody on this forum ever put in a shelved down 250r 200cc motor or a MTX200R motor into a 200x frame trying to make a replica 200r factory racer ?also you can use this page as a reference it has a couple picture with 200x fames with 2stroke motors in them . http://www.3wheelerworld.com/race.shtml
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by HaggLE
    No offence ment here but I have to laugh my butt off everytime someone says this is easy. Frame mods should only be done by people that really know what they are doing and most don't. Even mounting the radiator would be a challenge above your average wrenching skills. It may be easy to some but it's out of reach for most to do it right.
    Newfoundland
    5,280
    Agreed, I'm pretty handy but I'd have to think twice before I cut the frame of my bike. Best bet for someone trying this project is to get a spare frame and use that as a guina pig for the swap.
    Mar 2004
    2,712
    Along the same lines, I wouldn't think anyone would want to use the 83-85 200x frame anyhow(without major gussets) as they were known for being weak anyhow.
    Newfoundland
    5,280
    Possibly but most CR conversions I've seen have been the 85 model and not the 86/87. The CR motor would be lighter and not put as much stress on the frame.
    Jan 2005
    330
    I say its easy with the assumption that you can use a welder and a grinder.
    We are making trikes over here, usually from bikes but you still have to make triple clamps and swing arms etc..
    The reason that dad made these trikes was because 250r's were only new and a little more pricey plus i think he had his 200x from before the r's were out.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    ACTUALLY 250R'S CAME OUT IN 81 thats years before the 200x,,,
