Results 1 to 8 of 8
Thread: My Tri-moto(need help)
    Mar 2004
    Fond du lac,WI
    658
    :? My tri-moto 200 is acting up when i hit the gas it will bog
    down and then if i let got it will pop like a firecracker anyone know why also
    my pull start handle snaped and the cord went in anyone know how to fix that problem :?:
    What does the plug look like?
    84 Honda Big Red w/plow
    85 Honda 200X
    88 Honda CR 125
    86 350x(in process of building)
    :trikesown :Beerchug :trikesown
    Mar 2004
    Fond du lac,WI
    658
    :?: Sorry but what plug :?:
    Jun 2003
    South of Rochester, NY
    3,471
    I'm assuming he's asking about the spark plug. You can tell alot about temps and air fuel ratios by looking at the color/condition of the spark plug.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Mar 2004
    Fond du lac,WI
    658
    I took a look at it and the plug was pretty bad so ill get a new one and does anyone know how to fix a pull start
    Jan 2004
    216
    First off, take the rewind off the bike, The pull cord is the inner most part of it, so you are going to have to remove everything carefully until you get to the "pulley" per say which has the rope around it. Seeing as how it's already apart, and the rope broke once, you might as well put new pull cord on. Knot it in the "pulley", and then wind it around. There should be enough rope sticking out for you to put it back thru the outer casing of the rewind, and you can tie your pull starter handle back on, so the rope doesn't slip back thru. The following link tells the rest.
    http://www.3wheelerworldforums.com/viewtopic.php?t=20832
    96 Warrior - 90 Moto4 - 86 Big Red - 85 Yamahauler - 84 Yamahauler - 82 Big Red - 79 Trail 90
    Mar 2004
    Fond du lac,WI
    658
    :-D Thank You sooo much man :-D
    Mar 2004
    Fond du lac,WI
    658
    :? so i wind the cord on the right side
