I just got a go-cart last night for $100...needs TLC but runs :-D .I would like to know how to take the govenor off...it has a 5hp briggs&stratton motor. Can anyone help me... thanx
"I am going out of this world.....the same way I came in...screaming and covered in blood."
i think the govenor it's by the carb... it's by the throttle arm
What will it look like? Is it a screw?
yea.. it's a screw thats like 1 inch long
Ok,I found it...do I loosen or tighten it?
Thanx...I will ride her later...She sounds and runs better too :-D .
It just helped on acceleration...it takes off like a rocket :shock: . It still doesn't go faster on top end...is there anything else I can remove? thanx
well i'm glas to here it help... how fast dose it rougly go... and their isen't much you can do that i no off
Well, my engine is running kinda crappy,(fuel delivery probs.), but it goes good. Roughly,it goes about 20 mph...
Hey, i just built a racing go kart, 5hp briggs motor, bent, welded, cut all metal. Anyways, heres how you can make it faster....
1.) Mess around with your gear ratios.
2.) Billet Rod
3.) Dyno Cam
4.) Get carb blueprinted
it all depends on how much money you want to put in it. If you want a fast motor, find a builder who will do it.
get some nitrous and run it on alchohol and mess with the gear ratios...or fab up new mounts and put a tecate motor in it or something...
Wanna race? ;-)
85' Tecate (still looking for entire front brake asembly...)
bonanza mini-bike
if you cant ride with the big boys...put it back on the trailer
bore, hone, bigger carb, gear ratios, pipe wink
Curtis
Currently Trikeless- but I have a LT250R
Here is what I was thinking yesterday,has anyone seen the T-rex from kawasaki?Well I was thinking about cutting the rear end off it, and putting the zinger on the back of it. I don't feel like typing details, but what do ya'll think?
