i seen a post a few months ago about this.i just seen it in my rocky mountain atv catalog today.does anyone recommend this thing,does it actually work?if it would smooth out a few flat spots,id buy it......
I recently purchased one for the tri-z, it is the best upgrade you will ever buy, you will never have to re-jet, it does all the work itself, no piston meltdowns ever again, and the throttle response is phenominal, it will cure those flat spots, and I highly reccomend it other wise.
PastRides
Originally Posted by atctim
I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!SOON MY PRECIOUS!
What trike do they fit?
84 Honda Big Red w/plow
85 Honda 200X
88 Honda CR 125
86 350x(in process of building)
:trikesown :Beerchug :trikesown
it works on any carb, anysize. It will work on all your machines!Originally Posted by smokinp
'84 Honda 200x
slow restro
I have had mine for over a year now and I highly recommend it, it's worth more than it weight in gold and have tried to get everyone I know to go out and buy one.
86Honda250R
85Honda250R Sold
82Honda250R
Tiger 200 198? Sold
Tiger 250 198?
Tiger 80 (need engine) Sold
85 Tri-Z
86 Tecate
Perfection consists not in doing extraordinary things, but in doing ordinary things extraordinarily well.
What does it do exactly?
Where do you get one? how much do they usually run? How do they hook up?? Thanks
im gonna look into it a little more,but it sounds like a winner,it is like 65$ for my 350x.ive wasted 65$ worth of my time fooling with jetting and such.should you set your carb back to factory jetting and such,then let the dialajet do it from there?
what is it. who makes it. what does it do. and how much . any puics or links? thanx
m/m
I have a dial a jet installed also. Highly recommend it!
Link to site.
http://www.thunderproducts.com
1986 ATC 350X
1986 ATC Big Red 250ES
I think Im getting one. But do you have to put your trike back at the factory jet? And if I add a racing pipe will I just have to install Dail-a jet and it should be right?
I hope so, cause I have spent hours jetting bikes to get them right, it sounds good and if it is better and quicker to jet my trike with the new pipe?, Im going for it.
BP
The dial a jet comes with very detailed instructions, plus they have a 1-800 tech line that is very helpful if you ever need it. Basically what you do is jet your bike lean, then install the dial a jet, and it gives the enigne the exact amount of fuel it needs at any given temp, altitude, throttle opening,etc. You can install an after market air filter, or pipe, and the dial a jet compensates the for the jetting change all by itself. You can buy a dial a jet for about any engine on the face of the planet, marine,sleds, bikes, auto,etc.
PastRides
I just made that post up three days ago.Do people not like me or something.Whatever!!!!\
Self proclamied post hog ,get your own topics dammit.
My old 1985 250R http://www.flickr.com/photos/24898661@N07/show/
Feedback http://www.3wheelerworldforums.com/s...feed+back+edog
Currently trikeless
sounds kool i might get one
:-D :-D
that must of been your post i seen edog,i thought it was like a month ago...at least we have some responses now
