Thread: 200sx motor in a 200s???
    thehickfarmer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    i was wondring if a motor from a honda trx 200sx would fit a honda 200s...
    No it will not, the SX is a shaft drive and the S is a chain drive, a 200x motor will fit into a S frame though.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Rittman, Ohio
    6,276
    The TRX200SX is chain drive. The TRX200 is shaft drive. I dont know if it will fit into a 200s, but the motors are very similar. I assume you are looking at the electric start and reverse as the reason for the switch, otherwise there is little, if anything to be gained.
    Quote Originally Posted by TimSr
    Are you sure that the 200sx is chain drive?
    1986 ATC bigred250es
    1985 ATC 350X
    1985 ATC 250SX (Sold)
    LT230S+RM250=quadracer 250 (Custom project)
    1997 MXZX 440
    Nov 2002
    Kirkville, NY
    3,831
    The 200sx quad is chain drive. I think the top end is more like the 86-87 200x then like the 200s.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    mojave's Avatar
    mojave is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    southern indiana
    266
    the 200sx i have looks like the front mounts are different than my 1985 200x and the exhaust comes out at an angle instead of straight out the front.and i just purchase a top end kit end they are the same as a 86-87 200x
