I know you probably thought the motor was in the trike...but look how close the mounting holes appear to be. Can someone measure the mounting holes placement on the respective engines. I may get to do it this week...but if anyone has a Tri Z and a YZ....let me know:
This is a project with serious potental. There are also big bore kits of up to 300 cc 's for the modern YZ that could make it a 50 hp motor.
The only issue I see is with the pipe and maybe the airbox and carb. Obviously you would fabricate some airbox set up and get rid of the Tri Z high breather system.
