Results 1 to 8 of 8
Thread: Snorkels ( please reply)
    Mar 2004
    Fond du lac,WI
    658
    Hi everyone i just feel so dumb coud someone answer me this question lol theres 3 lol what does a snorkel do and hows does it work and can it hook up on my tri-moto 200 oh and how do i put it on the carb
    Oswego, IL
    1,858
    well iw as thinking about makeing one for my x. all iw as going to do is take some pvc or sommthing and then come off the carb and go up out behind the rear fender and up about a foot or two above the rear of the fender and then put some kind of air filter on the end of it. this would make it so you can go threw deep water and mud. you can also make one for your muffler. look in the april dirt wheeles there are some on the big mud quads.
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    Mar 2004
    Fond du lac,WI
    658
    :-D yea i got that issue but how does it hook on a carb
    Mar 2003
    Australia
    1,919
    I wouldent run it onto my carb. Id just run it off my air filter. I might make one for my 250es when its up and going (if i get it). Sounds cool, my 200es can already go through deep water imagine what it can do with a snorkel.
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Mar 2004
    Fond du lac,WI
    658
    :? so i just run a pipe off of my air filter? :?
    Oswego, IL
    1,858
    ya u could put a hole in the back and run some type of tubbing out the back but you could still want to put some filter on the end of it and u got to make sure you air box lid has no holes and you will have to use som rtv or some type of glue stuff around the hole so it is water tight.
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    350x front end
    JoeSuzuki's Avatar
    JoeSuzuki is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Ontario Canada
    172
    Make sure to plug the bottom hole in your airbox, then with PVC tube hook longer ones to the hole in your airbox that goes under the tank(not the one that goes to the carb). Make sure to put some kind 90degree at the end so it doesnt rain in it.
    Still learning how to use and abuse my toys.
    Jul 2003
    Limerick Maine
    91
    your only gonna be able to go so deep before youe wheeler starts to float....then its gonna want to flip upside-down.three wheelers float better upside-down than riteside-up
    PUT SOMETHING HOT BETWEEN YOUR LEGS(350 X)
