Results 1 to 15 of 21
Thread: 1985 Honda ATC 250R
    Mar 2004
    Orange, CA
    34
    1985 Honda ATC 250R
    hello all you trike gurus, here an easy one to answer: I have a 250R with a fairly fresh piston in it, I need to know what everybody runs their oil mixture at, keeping in mind that 2 strokes generally run richer as they age. I have seen both sides of the piston and no grooves, so its good. I ran 28:1 the first time I rode it, the oil wasn't dripping out of the tail pipe but it was too rich, it did however blow perfect smoke rings. The temp conditions are 75-80 degrees F, Southern CA dry, The bike is totally stock and I like it more than my 2003 YZ450F. JUST KIDDING!
    Clarks Summit PA
    1,236
    what kind of oil you running?
    Ride it like you stole it! And never look back! They are too far behind to see!
    Mar 2004
    Orange, CA
    34
    Yamalube, cause its the best!
    clong's Avatar
    clong is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2004
    386
    What up Chris McDaniel?
    Welcome to the board. I would run Yamalube 28:1 as your doing. Run it as rich as you can without fouling plugs. Adds life to the engine. How long you had that 250R? Do you like it. Those things are so fast.
    1986 Honda 350X - stock w/ supertrapp, K&N, DG wheels
    1985 Honda 250R - OEM fresh trailer queen, but I'll ride it
    1985 Honda 250R - "rider" but still pretty original
    2005 Yamaha YZ250 - stock
    2007 PW50 - stock
    2005 Chevy Silverado crew cab - red, 5.3L
    Mar 2004
    Orange, CA
    34
    I love it, my buddy sold it to me, it used to be a piece of......... some new plastic, love and alot of coolant and gear oil changes since I've owned it and its never left me stranded so far. The thing is fast no doubt, faster than anyone should go on one. I use it to light off fireworks in the dez off my six-pack-rack, any idea where I can get a mug-buoy for the handle bars to carry my beer while I shift?
    previous rides: 87 KX250, 86 KTM500, 84 XR500, 97 XR400, 96 RM250,96KX250,
    97CR250, 98YZ400F, 2000YZ426F, 2003YZ450F Secondary: 02 TTR125, 03 Blaster, 02 XR50 Watercraft:SeaDoo XP787 Snowmobiles:87 indy Trail, (2) 88' indy 400s, (2) 89' indy 500s, (1) indy 500 EFI. (1) 93' 650 RXL, 02' RMK 800 and a 85' 250R
    clong's Avatar
    Jan 2004
    386
    I'm getting a drink buoy for my 200X. YOu get them at boat/marine hardware stores. You can't ride fast with a drink buoy but there good for cruzing around at night when you want to relax and bring a beer.
    2007 PW50 - stock
    Aug 2002
    New York
    1,098
    That's OK...I run Honda HP4 in my YZ426. I run HP2 in my R's at one bottle to 5 gallons of VP. I assume 32:1 is the mix.
    Jan 2004
    20
    Buy u some castor 927 and run it 40:1. Best oil I ever used. Whats your compression on the piston? If its over 10.5:1 then get u some high octane fuel. That R will run then.
    Mar 2004
    3
    I add one 8oz. bottle of Neo (blue) oil to 5gal. of Av gas. Your going to need to play with the jetting(increase) and watch your plugs closely for the first few short rides and then, less as you go. Just start with a larger main jet than you need, to begin with. Better to start too rich than too lean. Have an assortment of jets on hand and decrease the jet until you get a slightly dark(not wet) plug. When you think you have the right jet keep a carefull eye on your plug initially. Also keep a supply of new plugs that you can make a more accurate appraisal of your jetting. Once your finished you should not get much smoke at all, but the sweet smell of Av gas and Neo oil, better throttle response and less plug fouling. Have fun, take it slow, and watch your plug. I used to live in Yuma AZ and this oil is what all my friends were running on their 2 stroke Hondas. It is hard to find, so you might want to stock up on it once you find it. It is a pain to get the jetting just right initially, but once you do, it will be worth it. It was for me and and everyone I rode with at Glamis and Buttercup.
    85 250R
    Paul Turner Hi-Rev Pipe
    Mar 2004
    Orange, CA
    34
    85 Atc 250r
    Thanks guys thats a little more than I needed. I really only use this thing for night time activities. Its completely stock, I have no intention of making it faster and I want it to be reliable and last me. If I want to go fast I just hop on my YZ450F. So one more time does everybody agree with 28:1? It has never fouled a plug with that mixture, I haven't had to touch the carb and I love the convenience factor of pump gas.
    clong's Avatar
    Jan 2004
    386
    Stick with the 28:1. It won't hurt anything. Sounds like your a little conservative with your "R". Thats good. It will last longer.
    2007 PW50 - stock
    Rittman, Ohio
    6,276
    If youre going to run Yamalube, Id bump it up to 32:1. Over oiling accelerates buildup and deposits, shortens the lifespan of silencer packing, causes excessive smoke, performance reduction, and offers no improvements in lubrication or engine life. 28:1 isnt that bad, but Id bump it up a little.
    Mar 2003
    Barnesville,Ohio
    2,298
    Quote Originally Posted by Chris McDaniel
    WHAT?!?
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Yamalube is not my favourite oil...the best oil is Amsoil...or motul
    1986 ATC bigred250es
    1985 ATC 350X
    1985 ATC 250SX (Sold)
    LT230S+RM250=quadracer 250 (Custom project)
    1997 MXZX 440
    Apr 2004
    30
    Back in my racing days I used to run Bel-Ray MC1+ at 50:1 and Cam2 Supreme (104 octane)fuel with proper jetting, never fouled a plug or blew much smoke. This was on a 250R with a Paul Turner National engine.
    A lot of people get oil/fuel mixture confused with air/fuel mixtures. With any decent oil, I'd prolly run 32:1 and work on your jetting (idle, slide, & main) for the best performance and engine life.
    Kris
