Results 1 to 8 of 8
Thread: what to do if submerged trike??
    Jan 2004
    UK DEVON
    101
    hi me and my m8 are planning abit of fun over the weekend and the whole place is flooded here!! (uk). befor i go and take my z through too much deep water i was wondering what the consequences are if it sucks in aload of water? will it need a new engine? what would i have to do?
    thx
    nipps
    Bartlett TN
    3,083
    Flip it up side down and drain all the water out of it. Open the air box and drain it and also take the plug out before you start it. Oh and most important....start praying. But seriously, I have sunk many big reds and done this and they run fine afterwards...........peace
    86-87 Tecate ROCK!
    Aug 2003
    Reno
    203
    drown
    Good advice.
    My buddy crashed his Tri-Z into a canal once.
    I would add changing the oil to the above list.
    So pull the plug
    Turn it over
    Drain the airbox
    Change the oil
    Run it to evaporate whatever moisture is left in the engine.
    Earnest Hemingway:
    "Motor Racing, Mountain Climbing and Bull Fighting are the only true sports.
    All the rest are children's games played by adults."
    Jan 2004
    UK DEVON
    101
    thx so it won't go and fly to bits if it suddenly gets a drink? i've heard about hydrolaking the engine!! but only on cars!!
    nipps
    Bartlett TN
    3,083
    Well now if you keep it running while its sucking water into the engine, then sure its going to lock up bigger than heck. But if it just goes under and dies, then do what we say and you could be fine.............peace
    86-87 Tecate ROCK!
    Billy Golightly's Avatar
    Live Oak, FL
    15,068
    If the water goes past the snorkel and the water goes from there all the way through to the airbox, and then into the engine, your looking at some serious problems since water does not compress like gas. At the very least a bent rod. At the worsest, a broken rod, destroyed topend, and an un-repairable inner cases. Be verrrrry careful exploring the "Deep part".
    Hampton, Virginia, C.S.A.
    2,664
    yep billy good advice there but pulling the plug draining the oil and everythin u will have to do to
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    If you get water in the crank case, use tranny fluid to clean it out.
    I got my 250sx stuck in the river last year, the guy with me had to tow me out. I got the trike started and back home, but when I looked at the dipstick the oil was like a milkshake.
    I drained the oil and put 1/2 fresh oil and 1/2 tranny fluid back in. Started the trike, let it warm up and then drained the mix out. Tranny fluid absorbes water.
    I then put fresh oil and an new filter in and it was as good as new.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
