Thread: axle powdercoat??
    Jan 2004
    Warren, Maine
    54
    axle powdercoat??
    should i get my 250R axle powdercoated? or are the tolerences to tight for it?
    Dec 2003
    Ontario, Canada
    235
    I dont know what look you are going for, but on my one 350x i hung it from the rafters in my shop, put it in 6th gear my friend gave it a bit of throttle while i held sand paper around the axel, and polished both sides of, it looks just like new, took some time to do but well worth it
    1986 452x, 4inch westcoast swinger, full exhaust, and stage 5 racing kit
    99 honda 300 4x4
    06 Forman 500 4x4
    07 Fourtrax 420 FI
    Previous rides
    81 250r, 83 Cr 250, 85 250 big red, 80 185, 84 200s, 83 KLT 200, 86 Alt 185, 01 WR 250, 83 250r, 84 250r, 1986 350x, 1985 350x, 87 350x, 91 big bear, 01 DS 650, 03 Kodiak 450.
    Indiana
    192
    you can have the "fit" surfaces masked off so they dont get the coating. i would have the splines masked too, that way you sure your hubs will still fit, unless your bubs have some play, then you would want them coated too. where i used to work, i sent out HSS gear cutters to have them TIN coated and we would mask them off so the coating didnt adhere to certain areas.
    Tim is the name
    85 350X(86 motor)
    83 200X(stripped down for a total rebuild)
    85 200S(project)
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    What i would do it sand it with 600 grit,and then clear coat it.
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    I sanded my 185 axle, and the damn thing rusted to crap
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
