Results 1 to 8 of 8
Thread: pull sart and....
    Mar 2004
    Fond du lac,WI
    658
    pull sart and....
    i just got my pull start rebuilt and everything on it is new so i hook it up and pull it all works fine but my trike wont start so i pull and pull then the cord wont go back in. I have to shake it around and then it will slowly go back in. Does anyone know why?
    Also my 3 wheeler is having a hard time starting i know i have to adjust the carb but it dont whant to kick over anyone know why? Thanks :-D
    Nov 2002
    1,189
    Has the rope frayed? or are a lot of parts creating friction? HAve you checked for spark? If it does, does the plug have gas on it? Is the idle high enough? Is your air filter clean? Etc...
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Jan 2004
    selma
    186
    mm
    don't use a thick grease on the pull start try to use some like silicone lubricant, thick grease tend to clog it up thats what my friend did on mine ...used like axle great the thing would just sit there limp.lol
    Ride fast Ride Hard!
    Currently Own
    81' honda 250r Looking to sell maybe PM me
    Just Got my 84' honda 250r!
    81-83 185/185s currently SELLING! Pm me
    honda 200 198?
    check out my sites
    http://user.cavenet.com/compaqcoci
    http://www.f-d-rolls-bentley-parts.com or www.fdrbp.com for short!
    I live in Selma, Oregon 97538
    Mar 2004
    Fond du lac,WI
    658
    yea i just fixed it but i just found out something: my 3 wheeler has a key that u turn then pull it well with that said i was on it and i turned the key and it started to high idle and run ok except if i hold in the throtle for 3 sec or is it will sound like the carb is shuting and opening kinda of like a cd that was scratch and i turn the key and the idle drops a bit. Is it an electrical problem???? and how can i tell if the air mix and gas is set right??
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    what it is it?
    What type of machine is it?What year is it?Is it the picture that is your avatar?
    Mar 2004
    Fond du lac,WI
    658
    Yea its a 1983 yamaha tri-moto
    Nov 2002
    1,189
    I have th same trike, and it should only run when the switch is on on, not off, or the light mode. I don't think electrical would make it rev up for no reason. Hmmm.
    My Rides
    Yamaha 200E
    atckowalski is offline Formerly "aaakowalski" Arm chair racerJust too addicted
    Nov 2002
    Northern Mi.
    516
    Try cleaning the carb.One of mine ran something like that before because the main jet was gummed up.
