Results 1 to 2 of 2
Thread: Need some help 350X
    Mar 2004
    42
    Need some help 350X
    Just got a 350x not to long ago need some help.
    1. When it first starts up it smokes just a little (white smoke) after warm it really doesnt somke. Whats causing this?
    2. How much compression should I have? I have always heard that they have a lot of compression but mine is not terribly hard to kick, It is a little harder than most other bikes but not real bad. I weigh 215 pounds this might have something to do with it? I can pretty much stand on the kicker lever and it wont go down? does this seem about right? I do have the decompression cable also.
    3. For some reason I can ride it for awhile then if I turn it off or it stalls for some reason, Its seems like it doesnt want to start back up. If I turn it off and try to start it like 5 minutes later I have to get it started on the first or second kick if not for some reason it wont start unless I let it sit then try again about 5 minutes later. Then I have to get it on 1st or 2nd kick if not I have to repeat the process again.
    4. I was told that I could cut some holes in the airbox lid and get a little more out of it, if I did this would I need to rejet? I was going to cut the holes then put some type of screening over the holes to keep the mud and paticles out but Im not going to if I have to rejet. Im also gettting a uni filter soon.
    5. Im extending my swingarm 5 inches - Where can I get the extended brake line? Also what length of chain will I need after extension? 520x(?)
    Im getting a top end gasket kit this week I think I needed a new head gasket because it seemed to be leaking something out of it, really small amount but Im taking care of this before I ride again. Any damage this could have caused?
    If anyone can answer any of those questions, Thanks
    Ddw350's Avatar
    Ddw350 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    #2...i noticed if the decomp cable is adjusted correctly,you can kick it quite easily,sometimes i can stand on my kickstart for a second or two,then it goes down.its done this forever,i guess its normal,even with a new cable...
