Did you pull the plug cap all the way off and pull it far back enough from the plug? Sometimes the electricity can travel 1-2 inches or more!! and if the spark plug is still within that distance it will fire. I have a lawnmower that will run with the spark plug wire 2 inches away (I amazed my friends for days
) whenever I took the wire any farther away, it died. It could also be dieseling off of the heat I guess, but I couldn't image it getting that hot.
It sounds like you have a bad air leak, and if the kill switch isn't working its either a bad switch or you're wired up wrong.
Justin ~hondaATCman~
'82 Honda ATC 110
'81 Honda ATC 250r (Summer Project)
'87 Suzuki LT 250r Quadracer - Very Modded...FAST!!
'03 Yamaha Big Bear 400 4x4
'85 Ford Bronco II 4x4 2.8 V6
