Results 1 to 8 of 8
Thread: 250es motor question
    Mar 2003
    Australia
    1,919
    I was told my 250es did not have compression when i bought it. But i went out today to look at it and i kicked it over and it had nothing, the piston wasnt moving up and down.....It then "caught" and the piston went up and down, lots of compression cause it was hard to push down. It goes in and out of catching and sliping. Its not stripped on the shaft either. Do you think one of my starter gears inside the case are stuffed? Or maybe my decompression is buggered?
    I will try and hook up a battery tomorrow and kick her over with the electric start and see if she runs.
    Thanks In Advance,
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Apr 2002
    s.w. michigan
    6,498
    es ?
    there ain't a decompression release device on the es/sx modles matt so it is more then likely a little problem in the kicker gears.
    john
    Mar 2003
    Australia
    1,919
    Are you posotive about that becuase mine has a little 5mm copper pipe that goes from somewhere near the kickstart to the top of the head, sort of the same place the decompression is on my 200es??? Maybe its an upgrade for 1987???
    Thanks,
    Matt
    almac16 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Halifax, Nova Scotia, Canada
    226
    5mm copper pipe = oil line to me!
    Mar 2003
    Australia
    1,919
    What was I thinking.....
    Thanks,
    Matt
    renotrikeguy's Avatar
    renotrikeguy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Reno,Nevada
    433
    I dunno, maybe your just happy you have a new toy to play with?
    Chris (Reno,Nevada.)
    67 Honda CT-90
    75 Honda ST-90
    81 Honda 250r
    85 Honda 250es BigRed
    99 Honda XR250R
    04 Honda CRF150F - Cousins Ride
    Mar 2003
    Australia
    1,919
    Yep Chris, you have email.....
    Matt
    Howdy's Avatar
    Celina, Ohio
    10,079
    Re: 250es motor question
    Quote Originally Posted by atcmatt
    Thanks In Advance,
    Matt
    I can tell you with a lot of confidence what the problem is. 99% of the time it is a worn out "One-Way-Clutch" ( Honda calls it a "clutch, Sprag" or "clutch- one way" ). This is a very common problem on the 250cc 3 wheeler motors. I have replaced 15 or 20 of them ( all different machines ). The part is #10 in the picture below.
    There have been a few topics on this part going bad. You might want to read a few of these ( save me from typing it all over again ). Here is some of the threads ( Thanks to the forum seach option above ):
    http://www.3wheelerworldforums.com/viewtopic.php?t=17870&start=0&postdays=0&a mp;postorder=asc
    http://www.3wheelerworldforums.com/viewtopic.php?t=17165&start=0&postdays=0&a mp;postorder=asc
    http://www.3wheelerworldforums.com/viewtopic.php?t=11460&start=0&postdays=0&a mp;postorder=asc
    http://www.3wheelerworldforums.com/viewtopic.php?t=2472&start=0&postdays=0&am p;postorder=asc
    I hope this helps.
    Howdy
