Results 16 to 30 of 47
Thread: tri z max vertical drop!?
    Mar 2004
    82
    lol so by that logic an airplane could be dropped at 30,000 feet right to earth and it would land the same as it normally would.
    Eastern Long Island
    1,688
    Quote Originally Posted by XFR_Dozer
    I don't think a trike generates lift when it is moving forward!
    Lots O Trikes!!!!!
    YAMAHA_Jim's Avatar
    YAMAHA_Jim is offline 4 Motos, 3 Wheels, 2 Classes, 1st Place Arm chair racerJust too addicted
    Apr 2003
    Rock Hill,NY
    1,000
    200xman took the words outta my mouth lol
    ,,,i have an idea for another topic
    Mar 2004
    82
    im not physics professor ,but in a real world application trajectory has a direct effect on the force of landing impacts. on most jumps the farther you go the higher you go so the landing trajectory is somewhat similar but on a drop off you can flatten out that trajectory, the farther you jump lessening the impact. The flatter the flight path the more energy is diffused into forward motion upon landing. We agree to disagree on this one.
    Las Vegas, NV.
    2,490
    Sounds like TriZ_Jim & the Xman have some aviation knowledge.
    Mar 2004
    82
    hmm
    Las Vegas, NV.
    2,490
    I understand where you're coming from Dozer. I think you said it best though, "let's just agree to disagree."
    timex69 is offline Just Too Addicted Arm chair racerJust too addicted
    Sep 2003
    Saskatchewan
    485
    Could ya do us undereducated folks a favor..speak some english man :P
    Apr 2003
    546
    Quote Originally Posted by timex69
    lol... i am not over educated but that makes good sense to me ...the farther out you go ( trajectory)..the less the impact....i concur
    1985 ATC 250R
    2006 TRX450ER
    RIDE RED...IS THERE ANYTHING ELSE??????????
    Las Vegas, NV.
    2,490
    On earth, the force of gravity is pretty much constant, and falling objects accellerate towards mother earth at the same rate, which is roughly 32ft/sec. If you jump straight down off of a cliff, the small area that you land in will absorb all of the impact, and you'll probably leave a dent in the ground. Now, if you're moving forward when you jump off of the same cliff, a larger area will now absorb the same impact, and you probably won't leave a dent in the ground. What I'm trying to say is, regardless of the trajectory, the bike is subject to the same impact. By adding some trajectory into the equation, all you're lessening is the impact in a localized area which is better for mother earth not you, and that will make the BLM, Greenpeace, & tree-huggers everywhere happy. Remember my motto, "Adding trajectory to your jumps, saves the earth from nasty bumps!"
    Mar 2004
    Eastvale, CA
    630
    Red Rider, You're a rapper too??? Damn!!! I remember the Dirt Wheels article your're talking about and you never duplicated their 8' drop off, you did 4' max. If you recollect though, I safely landed a 12' drop off, only bent my handlebars and my shorts cleaned right up. But your buddies Tecrappy didn't fair so well.
    YAMAHA_Jim's Avatar
    Apr 2003
    Rock Hill,NY
    1,000
    With all of that said, I will add this.
    The wheels and susp are what absorb the landing.From a straight drop the wheels and shocks dont fair too well(say 10'),,,,,now drive off a 10' cliff at 30-40 mph(landing on flat ground)the wheels and susp absorb the landing quite well. At 80 mph the landing would still be rough but alot smoother.
    The same rules apply to high speed car crashes,when people get ejected they just bounce and skip on the ground,,,,which makes for some good road rash. Whats bad is when you get ejected at 75mph and your body goes THUD against an inanimate object.
    Las Vegas, NV.
    2,490
    Fo' sheezy ma' neezy. Mr. Sandman, the 12 footer, that you accidently rode off of, must have done some damage to your ability to remember facts correctly because my buddy wasn't riding a Tecate back in those days. Can't you remember how his front tire blew out on his '84 250R, with a 300 big-bore kit, when he bailed out? Also, while it is true that I started out on the 4' dropoffs, I eventually worked my way up to the 8 footers.
    TriZ-Jim, let me see if I understand this correctly? Using your logic, I would fare better by being ejected from a car going 80 mph, than if I jumped out of that same car while it was parked.
    Mar 2004
    Eastvale, CA
    630
    RR, you're right, TW was on the '84 300R. It's still funny as hell though, but I still don't remember seeing you do any 8 footers. You may be a legend in your own mind!
    And to better understand what Tri-Z Jimis trying to say, change being ejected from a car to being ejected from your R while riding a wheelie down the street and losing it. DOH!
  15. #30
    Mar 2004
    82
    i believe jim is referring to the difference of sliding or rolling to lessen an impact or being a bug splatting on a windshield. if you would rather roll off a drop off as dead weight be my guest. i think id take another approach.
