'85 ATC 110. Shift from 2nd to 3rd and some times it slips back into neutral. Also when shifting from neutral to 1st it wont go into gear and then i have to shift it again and its fine.
Sounds like you just need to tighten your clutch plates, on the oil side there is a bolt and a nut, turn off your trike, loosen the bolt, and tighten the bolt with a flathead screwdriver untill you get resistance, then turn it half a turn counter clockweise and tighten the nut back up, but qwhen your doing that use a wrench and make sure the bolt doesn't move with the nut. By the way, i'm heading to toledo tommarow night, whereabouts are you?
1985 ATC 200S--no spark, parts for sale
85 YTM 125--needs a carb cleaning and set up
79 Suzuki TC125--dirtbike, now fully restored!
84 ATC 200x--Need a good frame, rear caliper bracket, and a blown up or barley running motor with a good clutch.
Message me if your interested or have anything i need
Toledo, OH
The clymer manual i have says to turn it in one full turn clockwise and then turn it counterclockwise until i feel resistance and then 1/8 turn clockwise again. Sounds opposite to what you described.
it pry is, i don't have my manual with me right now, but what you read in the manual is what you gotta do. If that doesn't work then you might need a new 1'st and 2nd gear
Most of the time when this happens the stopper pawl breaks at the bend. See #1 in the picture below.Originally Posted by jdparsons1
The second most likely thing I have found is the one bolt comes loose. See #2 in the picture below.
To me these are easy fixes. First timers it may take 1-2 hours.
Howdy
I have a 85 250sx that does the same would this procedure work for me too?
The 250cc motor ( sx & es ) is a lot different. The most likely problem ( shifting ) with it is either the return spring pin ( #8 Below ) broke or the shifter bolt ( #21 Below ) has come loose or broke.Originally Posted by 85 250sx
These are located inside the left side case. For a first timer this should take less than 1 Hour to fix. I fixed 3wheelerforevers 250sx in 20 minutes ( broken pin ).
I hope this helps.
Howdy
Howdy,Originally Posted by Howdy
My 250SX started having problems when downshifting it sticks and I have to pull it up with my foot. Do you think that the return spring pin is the culprit in my case also?
If so to repair this does only the left crankcase cover have to come off or both sides?
Thanks In Advance,
This could be a couple different things.Originally Posted by kdagenais
If it is just sticking when down shifting then I would say the one little bracket is broken. This would be part #6.
It could just be a broken return spring pin.
One thing to check or do before tearing into the motor is to try adjusting the clutch ( right side case ). There is a little adjustment bolt right behind the domed part. If adjusting the clutch doesn't help then you will moist likely need to remove the Left side cover. This should be the only cover you would need to remove to fix this problem.
Howdy
Thank You, Howdy!
Looks like I am going in again! I already did the clutch adjustment so that rules that one out and the clutch is only 6 months old. So I will have to tear it apart and see what I got. At least I know what side I need to look at.
