Results 1 to 14 of 14
Thread: what is stock compression reading for 1985 250r?
    bushwacker51 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Cherokee, Oklahoma
    267
    Was wondering waht the compression reading should be on a stock 1985 honda 250r. thanks in advance Glenn Oister
    ct
    1,396
    from 170 to 199psi on a warm engine with the throttle wide open while kicking, and the switch off
    May 2012
    China, Texas
    58
    So if mine is at 160 psi would this indicate in need of a top end over haul?
    Aug 2010
    Southern Oregon Coast
    932
    It would be a good idea soon
    Dec 2009
    Oklahoma
    780
    That about sums it up. If you live at higher elevation your readings will be lower also.
    May 2012
    China, Texas
    58
    Thanks for the input i will plan on doing this very soon. The bike is still performing really good I have noticed a slight lose of speed at WOT in six gear and on making a short turn at low RPMS the bike wants to load up a bit other than that performs well. I was reading on the technical sheet and it says compression to be at 142-170. In the thread it says compression to be at 177-199. Can someone please explain why the difference in compression readings. Thanks
    May 2012
    China, Texas
    58
    I live in China Texas which is really close to the Gulf so elevation is more on the low side here.
    PA
    3,515
    I keep seeing people on here saying they want to know the compression of there 2 stroke when they really want to know the cylinder pressure. Cylinder pressure is what is measured in PSI and has nothing to do with the compression ratio of the piston.
    just a pet peve....
    WWW.HREATV.COM
    May 2012
    China, Texas
    58
    Yes you are correct. I'm looking for the cylinder pressure, is it because the wiseco piston generates more compression Making 177-199 psi then the stock piston back in 1985 which indicates 142-170?
    82 250r's Avatar
    82 250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    Utah
    278
    Kicking the bike WOT with the ignition off is called a "compression test" not cylinder pressure test. The test is measured in psi and has nothing to do with compression ratio.
    Cylinder pressure is normally used during a leak down test.
    The manual should give the correct level for stock bikes but you may have to adjust for high compression pistons.
    Marc
    May 2012
    China, Texas
    58
    I was told it was stock from the guy I bought it from. I haven't done a leak down test yet. All I have is a compression gauge and was wanting to know the difference in compression stated in the technical Manuel versus what I read here. I read 160 psi on my trike and wanted to know if that is getting low and would need to do a rebuild before causing damage. maybe I need to do some more research. Thanks for the information though.
    82 250r's Avatar
    Mar 2007
    Utah
    278
    My manual states 170.7-199.1
    At 160 you are on the boarder unless your at 7000ft or higher...you will show lower readings at higher elevations but 160 would still be low. I'm at 5000ft and like to see 185+ on a healthy motor.
    I prefer to do a leakdown test before compression so I know the compression test will be accurate.
    Marc
    gus's Avatar
    gus is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2011
    tucson arizona
    453
    What you could do is replace your rings and that might help instead of doing a hole rebuild?
    May 2012
    China, Texas
    58
    Thanks guys, this helps I really appreciate the feed back.
