Results 1 to 9 of 9
Thread: compression release on my trimoto200
    will my tri moto start with the compression release stuck open, im askin if it will run long enough for me to manually un-release it....my cable broke... and im wondering if it can be rigged or not
    Aug 2003
    51
    Nope. Get a decompression lever off a YTM225 and get rid of the cable.
    My toys
    2003 Kawasaki Mojave
    1985 Honda ATC250es Big Red
    1987 Yamaha BW350 Big Wheel
    Howdy's Avatar
    Celina, Ohio
    10,079
    Re: compression release on my trimoto200
    Quote Originally Posted by Choppers4Life
    You can flip the decompression lever up to start it. Once the motor turns over so far it should automatically release. This is just how they work. I did it this way on the Yam 200 I had ( it was stolen ). Never had a problem.
    Howdy
    Nov 2002
    1,189
    There usually isn't a cable... It's just a lever that has a spring on it. When the valve is pushed down by the rocker, the lever comes down, since there is nothing holding it up.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Nov 2002
    Kirkville, NY
    3,831
    Yamaha put a cable on the 200 chain drive model because it is the only one without electric start. Yours can be used manualy it just doesn't have a tab and nice little rubber cover like the other ones that don't have a cable do.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Nov 2002
    1,189
    Oh, I never knew that! Thanks for imforming me! :-D
    My Rides
    Yamaha 200E
    thanks for your help guys. your info was much apriciated.
    Oct 2020
    New York
    8
    Would a compression release issue cause back popping into the carb while its running? The timing is perfect, has new piston and rings but it backfires into the carb
    Mexico
    9,018
    Quote Originally Posted by CluelessD View Post
    No. The decompression lever only controls the exhaust valve. Popping in the intake is usually related to a timing issue (cam or ignition) a lean condition or possibly an overly tight or leaking intake valve.
    If the problem seems to be worse when the engine is hot then I would be looking at the valve lash on your intake valve as it might be too tight.
    Next thing is to check for air leaks around the intake manifold and possibly a plugged pilot jet that’s giving you a lean condition.
