Results 1 to 8 of 8
Thread: lights...
    CT
    674
    lights...
    I have an '86 250SX with no headlight, only the guard.. Is there any low cost way of putting a headlight on it, I am tight on money right now, but I might be goin camping this weekend, and would like a light to see.. any help would be great..
    Thank you,
    Patrick
    86 Honda 200sx (needs alot of work)
    82 XR200R (runs great, now the daily rider)
    91 acura legend junker, selling to get a truck
    2001 GSXR600 Part out, PM for info or for parts.
    Bartlett TN
    3,083
    Well I have a really nice headlight system but like you said they arent cheap and hard to find. But since the SX is battery powered, I think you should be able to find some low wattage light systems at an auto place and put in the place of it for the time being.
    86-87 Tecate ROCK!
    CT
    674
    would hologen light kit fro dennis kirk ( 21-996) work? it has 2 hologen lights, a switch, and wires... would I be able to connect those in place of my origanal light.. like clamp em onto the forks between the triple trees?
    Bartlett TN
    3,083
    Sure they should work fine. YOu just need to make sure the higher wattage the more they will draw on your system.
    86-87 Tecate ROCK!
    CT
    674
    true.... maybe Ill just get the complete headlamp assy. for honda from dennis kirk.. it has housing, lense, bulb, socket, and lead wires, but its only for tc 110,185s, and 200s.. will it still fit??
    Bartlett TN
    3,083
    As long as it has straps to mount on the forks, it should work. Most likely it would work. If it bolts, you might have to fab it to work just right.
    86-87 Tecate ROCK!
    Rittman, Ohio
    6,276
    These are 35 watt (each) trapezoidal sealed beam, single filament lights from Autozone. I think they were about $15. These are the only thing Ive found that would stand up to normal abuse. They are mounted with a single bolt, upside down in this case. They put out pretty good light on my TriZ, but will probably work a lot better on the 350X electrical system.
    CT
    674
    would I have to drill holes into my top triple tree to put those on? And did they come with a switch?
