Results 1 to 2 of 2
Thread: Why wont it start.......
    Mar 2004
    Fond du lac,WI
    658
    :-D I was so happy when i got my pull start fixed so i could ride her. Then i will pull and it will start then i go for a ride i get off shut her off and leave for maybe 5 min go back to it and pull and it wont start why?????? :?:
    kwit is offline First Time Rider Arm chair racerNew to the board
    Dec 2002
    134
    well
    If you pull the cord and the engine turns then it has nothin to do with your pull start assembly. Make sure your compression release valve is closed.. . Other then that it sounds like it could be a carb problem(flooding out). Id take it apart clean it and adjust it. Also check your air cleaner and clean that too.
    current bikes: 1985 200x,Tricked sport goped,2003 magnum 330 polaris(my dad won it)
    old bikes:tricked racing 97 blaster,1983 kx 80,1983 200e bigred
