Thread: 84 200s pilot jet sizes for stock?
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    I got a nice 84 200s the other day and need to get the correct jets in the carb. I now the main is supposed to be a 100 but no manual mentions the pilot jet size. Clymer even says its pressed in and not removable (its not). It came with a 35 pilot and a 85 main. ran like crap too.
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    Dec 2002
    SW Alabama
    763
    The 35 is the correct pilot jet.
    Whiteman
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    I had a 200s carb, it had a 98 main jet, but yeah the clymer says the pilot jet is pressed in, i noticed that it said that about the 185 carb, and i have about 4 carbs, and none of them are pressed in, so they are obviously wrong about that
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    RichinMO's Avatar
    Aug 2002
    Waynesville, MO
    321
    Thanks for the info. The needle was also some aftermarket piece of crap, only had one slot for the clip, not 5 like the stock needle. I hit 2 Honda shops on Sat, looking for the correct needle and main jet. First place had nothing, 2nd place had a replacement oem needle kit and a 102 main jet (no 100). Went with those and it runs a lot better. The 35 pilot that was in it had the screwdriver slots bent up/wallowed out, that may be affecting my idle (couldn't find a new one of those). Took a good 20 minutes of screwing with the pilot screw to get it to idle evenly. Has anybody ever used the Moose carb rebuild kits that Dennis Kirk sells?
    1985 ATC250ES
    1985 ATC250SX
    1985 ATC70
