Results 1 to 8 of 8
Thread: Question regarding front hub/wheel
    nitekrawler is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2003
    430
    Alright, new problem. Got son a new (ebay) front wheel and hub. His hub spins good. A good full turn each time I spin it. The new one we just got, only spins 1/4-1/2 turn each time. I assume the faster one is better or? His old hub will not match up to his new wheel :?
    TIA
    1982 Honda Atc 250r - Daughter's
    1982 Honda Atc 250r - Son's
    http://forums.atvconnection.com/photos.cfm/ID/1566/#TOP
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    new bearings with fresh grease and good seals will have more resistance than old worn out bearings,,,,
    Jul 2003
    430
    So, its reverse? Wow, thanks for your help. Neither are actually new, so I wasn't sure how to tell
    cedar falls, IA
    546
    to be safe, you should just replace the bearings.jmo
    The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
    85 atc350x ('05 christmas present to myself)
    84 tecate (my baby)
    84 honda 110 (lil buddy)
    81 honda 70 (daughters ride)
    86 lt250r (sold for parts) R.I.P.
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    Does the new one rumble?? Does it feel smooth??
    When you say the old one spins one turn, do you mean that the trike wheel is off of the ground and you give it a big spin?? If that is the case It should go around more than one time.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Jul 2003
    430
    Quote Originally Posted by ATCnut
    Yes, smooth
    Nov 2002
    Auburn Washington
    799
    I forgot to ask the last time, why are you replacing?? If the bearing is smooth, then there is not a problem.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    85 350X (the best)
    Jul 2003
    430
    The new wheel came with the hub, and the old hub will not mount on the new wheel although, they look the same, they are off a pinch, weird. Different years maybe? Both are gold rims.
