Thread: Getting inserts out of plastic tank...?
    Dec 2002
    66
    :? :x I went to unscrew my bolts that hold on my engine/rad shrouds but the inserts spin. (Plastic tank) I've tried pulling the inserts out but they won't move. Does anyone know how I can remove the bolt or remove the insert so I can remove my rad shrouds without damaging tank? Help......
    Caution: Rider my bail at any time!
    Dec 2002
    66
    Brass inserts
    Got-it, thanks.....
    Curtis-Tecate3's Avatar
    Curtis-Tecate3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    352
    Well, How did you do it? I assume it is on a 86/87 Tecate right? I know mine are a trailprotrailprotrailprotrailprotrailpro to get out since I use loctite on alot of stuff. When I have a similar problem with a fastener in something like that I have used a soldering iron to heat up the bolt/screw and it will loosen up the loctite and help me get it out.
    Curtis.
    I love anything with an engine except a lawnmower...
    1986 Tecate and original owner of a 1985 200X.
    3 wheeling since 1975.
    Dec 2002
    66
    Plastic tank inserts
    The inserts is a 10mm brass looking nut. I pulled on the bolts until the insert was barely showing, then I put my specially made (thin) 10mm open end wrench on the insert and unscrewed the bolt. Kawasaki said that tank was form around the inserts. Basically, Good luck!
    Dec 2002
    66
    Re: Plastic tank inserts
    Quote Originally Posted by Full-Bore-2003
    Pain in the butt.....
