Thread: mike ft. laud or anyone that uses aviation fuel.....
    Jul 2002
    40
    could someone please explain the BIG difference between jet fuel and avaition fuel?
    May 2002
    46
    Simple - Aviation gas is high octane gasoline.
    Jet fuel is essentially highly refined Kerosene.
    8)
    Hope this helps!
    New Hampshire
    794
    Heh..
    DO NOT use jet fuel. Let me say that again. DO NOT USE JET FUEL. Jet fuel is for jet turbines, Which is a completely different animal.
    Av is a bit higher octane. I used to run it in my worked over 200x when i was racing and had the extra cash. Its most beneficial running high compression engines. Depending on where your getting it, you can pay upwards of 2$ a gallon for this stuff. Where I bought it, you could buy only in increments of 20 gallons for 35 bucks (saved a little cash).
    catfishwhisker is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2002
    237
    This should help: http://www.dragracingpinoy.com/tech_avgas.html
    Still looking for an "original" TC dual plug head for a 200X!
