350x-250x-300ex engines - compatible??
Hey all,
I've heard a long told rumour that the these engines are all based on the same cases. Is that true? Are parts interchangeable?
Any insight would be appreciated!
Kris
They look very similar, expecially the right case, you can even see the oulines of where the oil cooler should hook in on a 250x/300ex case. The 350x has a oil cooler. I think the 300ex even has a outline for a kick start, but maybe thats cause the 250x has a kick start.
I always wanted to put a 300ex head onto a 350x cyclinder cause the 250x/300ex uses a cam with bearings on it, not sure if everything would line up though. Its funny the 250x/300ex are 4 valves, but only have a single head pipe unlike the 350x.
//ArrowChat Integreation Code
