Results 1 to 8 of 8
Thread: reboring increased power?
    Jan 2004
    UK DEVON
    101
    hi i have to rebore my z and was wondering if there is an big power increase if i bore it out to the max(what is the one size below the max)? and what are the disadvantages? will i have to rejet?
    n what do you recomend?
    thx
    nipps
    Rides:
    86 Tri z phase 1 wrench report porting n DG pipe (this beast is what really got me into trikes!!)
    84 honda 200 big red
    84 yamaha 225dx
    "To scrout or be scrouted the question remains!!?"
    Watertown, New York 13601
    3,382
    bore it out to the max! That is a stupid idea.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Jan 2004
    UK DEVON
    101
    thats why i want to know the one under max?
    anyway what would u recomend i bore it out too?
    nipps
    Rides:
    84 yamaha 225dx
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,251
    the 2 mm's difference between stock and .080 is designed to give the cylinder long life,,, not a big power increase.. going 2mm will not make enough difference to even feel on a stock machine,,, you will get way more bang for the buck with a aftermarket pipe,,,, also if you do bore it out and have a problem instead of going to the next oversize you will be going to the cylinder store for a new cylinder or sleeve,,,,,,
    Dec 2002
    Kansas
    2,387
    Yes like Kasey said, you won't notice much increase. Just take it to the machine shop and have it bored to the next available size.
    A pipe and a port and polish job will give it the most bang for the buck. A port and polish while the cylinder is already off would be a great idea if you have the cash. I would say a port job from a respectable engine guy would cost $175-$250.
    I had the RIGHT to remain silent, I didn't have the ability!
    C W. is offline First Time Rider Arm chair racerNew to the board
    Apr 2004
    Key Largo FL.
    107
    jugs
    kacy and wrench know there stuf save the jug get a pipe
    Washingtons Crossing, Pa.
    2,977
    Any time you "overbore" any 2-stroke, you will actually lose power unless you match the ports timing angles back up to the new bore.
    Ashland City, TN
    2,576
    These guys are all right. I think the actual increase would be like 10CC's tops, which like they said will hardly be enough to notice.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
