Hi all, here are my questions...
How reliable is the atc200 ignition system? I searched the archives here and it seemed as if there were quite a few problems with the pickup, cdi box, coil and stator. Is there a rev limit? What is it? Someone stated that if you have a high compression piston then there may not be enough spark. Is this true?
I am fitting an ignition from a 200 onto my 1974 honda xl250. I have a 10.5-1 piston, megacycle cam, big pipe and carb. Redline is about 9000rpm.
Thanks everyone for a great internet resource. I've found a lot of useful info in the archives.
Pat
