HELP!!-Sputtering-1/2-3/4 Thrott., carb prob??
It's an 83 185s, I took all the jets out of the carb, cleaned them and sprayed out the jets and carb with compressed air. I didn't screw in the air mixture screw in and count, I just figured I'd go with how many the manual said, but it hasn't been working right since, I even stripped the carb down again and cleaned it again, just in case i had loosened a piece of dirt, that later dislodged when i ran the bike. It works perfect from idle to 1/2 throttle then from there to 3/4, it sputters, pops, and bogs out, and then from 3/4 to WFO, it works fine again. could this be my air mixture screw? i have tried turning it a little bit in both directions, but there was no difference. I ordered a new needle, slide, and seat, for the carb. would that have anything to do with it? I was told that they wear out, and make it not work right, so I am going to try that, but it'll be a week before that comes in.
If anybody has any suggestions, plz tell me.
thanks
Jon
Caution
Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
