Results 1 to 15 of 30
Thread: Tecate KX250 hop-up question?
    Apr 2004
    Lakeville, Mn
    10
    Hi guys! I've got a '85 Tecate that was running sweet up until last fall when the head gasket sprung a leak. Anti-Freeze then spilled into the cylinder and preceeded to score the cylinder & piston. Since the cost of a new sleeve or re-Nikasil cylinder was about $200, I decided maybe it was time to try the long awaited hop-up I've been meaning to try; The KX250 cylinder "bolt-on". Well, I found a decent KX250 cylinder (already sleeved) on eBay and had it rebored with new Wiseco piston. I also had the cylinder head and base slightly cleaned up to make sure everything seals up ok. Well, I put it all back together and tried firing that baby up. Nothing. I get the occassional 1 second rumble then she quits. My question is, has anyone tried this modification? From what I remember, it was recommended by Kawasaki in the Jimmy White Replica specifications. But if anyone has tried this mod or is familiar with it, do I need to do anything else? Different timing specs? I do get the occassional backfire. Jetting? I used the stock Tecate head gasket. And yes, I have spark, fuel and (plenty) of compression. Any ideas??
    wizzard is offline At The Back Of The Pack Arm chair racerFirst time rider
    how long did the bike sit up?
    '85 Tecate-project due....2029
    '85 350X
    Apr 2004
    Lakeville, Mn
    10
    I assume you are referring to when it was last running. Last fall. But I've tried priming it and that doesn't help. Something seems way off. I tried surfing the web trying to get the KX250 timing specs for '85 and I can't find it. Has anyone done this mod or can refer me to an article that has?
    Newfoundland
    5,280
    Well you bored the cylinder so arent you supposed to rejet because the engine needs more fuel/air to run the larger bore and compression...anyone care to add to this or tell me I'm wrong? The backfire would have me think your flooding.
    ange's Avatar
    ange is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2003
    utah
    195
    The KX cylinder breathes differently than the KXT one. The JWR manual doesn't specify how to set it up w/ the stock carb, because they recommend you getting a bigger 38mm flat slide...
    Sounds like too much fuel getting in. Take the exspansion chamber off and see if you have fuel sitting in the exhaust system... then you know if you need to lean it out some more w/ different needle settings or jetting changes.
    KXT 250 A1/A2
    Jun 2002
    Mississippi
    2,552
    that was my cylinder!!! it should be the same. make sure dirt dobbers have not clogged your pipe. that was my problem, lol. then get someone to pull start you. if you have fuel built up in the bottom of your engine it will never start with the kicker.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    "I get the occassional 1 second rumble then she quits."
    what you've described here sounds like something I had happen to a 250 R I had after I let it sit up for a while. Clean your carb out, specifically your jets. A can of degreaser, cotact cleaner or even WD40 should work. Put the straw (that comes with the can) in every port in the carb, spay, and make sure the spray is coming out somewhere else. This is the simplest way to clean your carb. Chances are your pilot jet is clogged and that's your whole problem. Take it out and try to look through it, if you can't see through it.....
    '85 350X
    Apr 2004
    Lakeville, Mn
    10
    Quote Originally Posted by ange
    Other than the 38mm flat side, do they recommend any other mods? They don't mention anything about advancing/retarding the ignition timing versus stock? Other than the carb, any other mods they recommmend? Where can I find a JWR manual? Anyone know if there's one posted online or the basic configuration (jet sizes, ignition timing, head gasket (kx-kxt), pipe, etc)? If Kawasaki has done most of the research, I'd like to piggyback on their R&D. Thanks!!
    Apr 2004
    Lakeville, Mn
    10
    Quote Originally Posted by 200x Basket
    200X Basket -- The cylinder has K&K scribed in it. What the heck is that all about? Did you sell it on eBay to rpjense? You ran this cylinder on an otherwise stock Tecate (carb, pipe, etc)??
    ange's Avatar
    Apr 2003
    utah
    195
    They give jet size and set up hints for the 38mm flat slide only.
    No timing information is given.
    Ebay is your best bet at finding a JWR manual. (none that I know of are scaned and online)
    I recently had a similar problem, it would fire maybe once, then thats it. It was just flooded out really badly. A bunch of gas in the pipe, and the bottom of the engine.
    Took the pipe off, got the fuel out, spun the engine a bunch to crank some of the gas out of the engine, drained the carb, then it started right back up.
    Start w/ the obvious. Is there spark? is the plug wet when you pull it out?
    KXT 250 A1/A2
    Jul 2003
    936
    i knew a guy that actually pulled that off...man that was a beast...you need a KX500 carbuerator to make it work good...
    Wanna race? ;-)
    85' Tecate (still looking for entire front brake asembly...)
    bonanza mini-bike
    if you cant ride with the big boys...put it back on the trailer
    Apr 2004
    Lakeville, Mn
    10
    Unhappy
    I just had it out at my brother-in-laws and we were bump starting it using his golf cart as a mule. She would run for 3-4 seconds and then die off. My bro-in-law is a big 2 stroke roadrace (tz Yamaha) gearhead. He said something about the engine being one large pump, and now that it's flowing better (less restrictive), it needs less fuel. Needless to say, I'd hate to spend the rest of Summer farting around with my jetting, slides, needles, etc. So I think I'm going to yank off the KX top end, get my old cylinder resleeved and go back to stock. After spending a total of $300 on the cylinder. bore job, cylinder resurfacing (head & base gasket), beadblasting and wiseco piston/rings, I'm going to cut my losses now. Stick it out on eBay and see what happens. 20 years ago, an Enduro racing buddy of mine always used to say; "Bob, when are you ever going to learn? Stock is best". I think it's finally starting to sink in!! Thanks Guys!!
    Jun 2003
    englishtown NJ
    2,676
    I wouldn't do that, I'm sure its something stupid. they used the kx igntion in the jwr manual, I've heard of sometimes bikes not running because of too small of a carb. I had a 36mm on my tecate, What carb do you have?
    Us
    727
    how much do you want for the kit?
    Apr 2004
    Lakeville, Mn
    10
    Quote Originally Posted by deathman53
    It's the stock 34mm. I'm curious about using the KX ignition. Did they recommend the KX ignition because of the lighter flywheel? Or is the timing different?? 38mm flat slide = $200 (plus jets, slide, needle), KX ignition & flywheel = $250. Ouch! This experiment is getting spendy. If someone wants to make me an offer, we should do it outside of this thread. robert.jensen@nwa.com (m-f 7:30-4:30pm cst) otherwise robert.jensen@frontiernet.com (weekends & after work). Thanks..
