Hey i need to know if the front axel on the 250es is a screw in at one end? It wont damned come out! I hate rust....
Thanks
Matt
Thanks
Matt
1980 ATC 70 Needs Restoration
1985 ATC 250es Fully Refurbed
1986 ATC 350x Mint Original
Yes Matt,
It does have a threaded end . Maybe you should soak the whole bike in WD-40 before you try to take her all the way apart.
Chris (Reno,Nevada.)
67 Honda CT-90
75 Honda ST-90
81 Honda 250r
85 Honda 250es BigRed
99 Honda XR250R
04 Honda CRF150F - Cousins Ride
yeah,,, i just had the front axle out of my big red puttung on the drive unit for the trip meter and it come apart real hard too. not the end that threads into the left fork but rather getting the axle back out of the hub.
the spacer inside the hub plus the axle bearings didn't want to let go !
finnaly got it out of there + greased it up a bunch before re-assembly.
i should put a grease zirk in it like i done on my 350x ,,, heck i'd just re-done the big red (frame up going thru ) 3 years ago and ain't been in that much water,,,
john
So let me get this straight....if i want to get the hub off, minus the brake panel, i just whack the axel so it comes out of the spacer? This is really giving me the you know whats and i realyl want to get the fork leg and that off!
Thanks
Matt
well i better explain this correctly ,,, i sure don't want to be responsable for helping screw up the fork legs or other parts - lol !
the front axle will unscrew out of the left fork (as you sit on the trike , the left side) ,,, you will need to loosen the 4 pinch nuts that are on the right lower fork leg.
and then when if every thing is perfect ,,, you should be able to pull the axle out the right side.
but i had to use a long peice of rod and beat it thru from the left side to drive my axle out the right side.
i would figure that yours ain't been apart in a longgg time so it's gonna be a pain to get it out of there.
john
Yep....
Tried it, i even welded the axel end to the vice and tied using my rear axel as a lever to urn the socket but the welds just broke off the vice, it is so %$# &*@! rusted in, oh yeah before i did all this i heated it up for a good 20 mins while continuously spraying lubricant into it. I guess i will have to pull the hub off (bearing carrier) somehow (any pointers?) and then cut the axel and drill it out. I probably will have to go to a fastner shop and get a new axel.
Maitenance is all that is needed to keep thiongs from freezing up........lazy people.....
Thanks John
Matt
yep,,, a little maintence will go along way. at least you have a parts trike to rob from ( hope it's goona come apart for ya ).
sounds like it was wayyy over tightened into the left fork leg to start with.
kinda like bottomed out the threads. they don't gotta be very tight ,,, just snug. the pinch plate thing on the other fork with the 4 nuts will keep it from backing out.
good luck matt ,,, i'll say a few curse words for you for support - lol .
john
Thanks John,
Yeh its is great having a parts trike otherwise id be stuck. I cant ge the front axel out of the other 250es either, its worse than the one now. I also cant get the nut off the main headset stem. It will turn, but its VERY hard and it wont loosen as you go any further. Im using some stilsons to undo it but i need something better. On a good note i got those 2 footpeg bolts out today, well i dident, my dad did but there out anyway. Hey John when you went through your red 3 years ago, how did you was all the parts? In a big tub? I washed my 200es parts in a laundry tub with washing detergent but i dont know if mum will let me do it with this one now that she has seen the damage i do....oops..., lol. Maybe ill ask if i can do a special load in the dish washer....do you think most parts would be ok to go into a dish washer? Air box and the like......
Thanks,
Matt
i sandblasted almost the entire trike matt. i have acess to one at work.
i had to send out the rolling chassis cause it was to big for out company sand blaster. i blasted plastic along with metal.
john
Aren't you glad you bought a new project to keep yourself busy Matt? I'd be more than willing to help you take your trike apart but im way over here..
67 Honda CT-90
75 Honda ST-90
81 Honda 250r
99 Honda XR250R
Im going to have everything blasted. Im going to leave the swingarm on the frame beacause i cant get it off. Do you think i should blast the alloy parts, brakes and the like of just wire brush them clean? Of course i would blast them myself with my blaster because its not very powerful but for the frame and that i will get a pro to do it. Im very glad i got this new trike but i just wish it would all come apart!
Matt
Now your making me feel bad,. I guess your Red will be done before mine is. Oh well I will just have to pay your brother to help you, that way it will take you longer.![]()
Not really, just make sure you take lots of pictures.
67 Honda CT-90
75 Honda ST-90
81 Honda 250r
99 Honda XR250R
Hell no, not at the rate im going now! I ended up ripping the old angle grinder out and cutting the trailprotrailprotrailprotrailprotrailprotrailprotrailpro off......I have the fork leg off now atleast. The axel is in 2 pieces, completely useless now. I tried to get the hub off and f*&%$# the bearings, so more money.... i still cant get the balls out of it though. Any tips how too? I had to cut the actual cast alloy on the brake panel to get to the axel.
Here are some pics showing what i mean...has anyone got ANY suggestions?
Pic 3- see how i had to cut about 1cm off the cast alloy on the brake panel...and i still cant punch out the axel or the spacer. I will need t ouse a spacer in there instead now....thats if it ver comes off!
Pic 2- See how rooted the end of the axel is from holding it in the vice and trying to turn it with the sockets....Also notice the bearings arent in their cage but are still there....how do i get em out?
Pic 1- I drilled holes in the leg to put bolt free stuff in it, wish i dident becasue it dident do anything and they look stupid! I will sand off that jb weld stuff and make it smooth.
Thanks for any pointers,
Matt
When this happens you really only have one shot
All front drum ATC's have the same problem - the axle gets stuck or seized inside to the drum bushing and the sleeve next to it. Unfortunately as you smash and heat and cut you ruin more items. Yes a simple dab of grease would have prevented it but thats not your fault.
For me when I get a seized axle or whatever I always get it into a milling machine and drill it dead nuts increasing sizes or using end mills till only a shell remains - not good news if you do not have access to a machine shop but I get out almost 100% of all my rusty POS for years now - as long as it fits in the mill and can be bolted down it is almost foolproof unless the item is hardened which requires carbide drills etc.
A hand drill just cannot drill a hole dead nuts for the inch or so required to free that up - and a drill press isn't much better.
Good luck
Thanks Crasher,
Damn this, im gunna smash it to hell and back! POS, is that sleeve that is inside the brake panel pressed in? Or should it be able to come out aswell???
Thanks,
Matt
