Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: 250es to 250sx
    bbechtel16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Halifax, PA
    400
    mmmmmmmmmmmmmmm...............350X front end......
    -'86 ATC 250SX: No longer mine... Complete 350X front end, Corbra Megaphone system, 350X carb with UNI dual stage foam & outerwear bolted driectly up, Powroll/Rocky 260cc bore 10.5 to 1 compression piston.
    Washingtons Crossing, Pa.
    2,977
    lol...... man shell out $15 and get some decent handle bars on that thing before you spear yourself!
    :Pimp
    Halifax, PA
    400
    Quote Originally Posted by Wickedfinger
    I would if I had any money. Can anyone recommend some good but cheap bars for the 350X front while we're on the subject?
    Mar 2003
    27
    well boys i had 4 250sx sold one today it was a cherry got 1500.00 but i still have a yard full of 3 wheelers to mess with
    3 250sx
    1 250es
    1 250r
    1 185
    1 200s training bike
    OK please prove it???
    ES has different gear ratios than the SX?????? Not in my Clymer - I've heard this rumor before and want someone to prove this please, show me the gearing change?
    The SX is geared low enough, I don't think they made another tranny or output to slow the ES down eben more. But they did use larger tires and wider rims I believe.
    Halifax, PA
    400
    Re: OK please prove it???
    Quote Originally Posted by Dirtcrasher
    The ES DOES have a lower final drive ratio (higher numerically) but its only to compensate for the larger stock tires (22" vs 25") so the effective ratios are the same. I read this somewhere before, it was an ES review I think.
    Final drive ratios - this could be true. I'd still like to see it on paper though.
    Others have told me in the past that the tranny gears are different and I don't believe they are.
