Thread: HONDA FOURTRAx 125
    cmracer15 is offline At The Back Of The Pack Arm chair racerFirst time rider
    HONDA FOURTRAx 125
    I have an old 87 Honda Fourtrax 125. And i was riding it and the front sprocket fell off and i cant find it. Im pretty sure it was the original sprocket. But the problem is the rear end is welded to the frame because the carrier kept twisting going around turns causing the chain to fall off. So i can no longer adjust the chain. So i Need another original tooth sprocket..im not sure how many teeth there were . And If possible i need to have it by this friday or saturday. I dont care if the thing is worn down or not..Its just an old POS me and some friends are taking to the mudhole this weekend and guna tear it up. So i dont care what the sprocket looks like as long as it will turn the chain..Thanks, Chris
    3 racing gokart's
    02 Kawasaki ultra 150 jetski
    02 kawasaki 1100 DI jetski
    yater is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2003
    Tyler, Texas
    672
    www.denniskirk.com -- go to their website and follow the prompts OR call the 800# on the site. They can overnight it to you or 2nd day. They are very reasonable on shipping too. You could try your local dealership--you may get lucky. It seems that it would be the same as the 125m sprocket but I'm not sure.
    Auburndale, Florida
    40
    quick fix
    just go get you any old sprocket for that chain size. drill and grind to make her fit then weld her to the shaft i mean weld the trailprotrailprotrailprotrailpro outa it or else she will break. And add or cut chain links if you need to. (thats how wee'd do around here in polk county ,Florida (home of the pimps)
    Auburndale, Florida
    40
    Hey CMRACER i think i seen you at bubbas mudranch in adale about 2 weeks ago with that 125. You was raggin the trailprotrailprotrailprotrailpro out of it, damn i suprised that pos still runs. As when i was leavin i seen you sink it. People like you is what gives adale its good olde reputation. THAT trailprotrailprotrailprotrailprotrailpro IS THREW LOL
    A blown up John Deere 111 with a 11hp b&s pushing about 20hp as of (7-17-04) yep she died
