Results 1 to 8 of 8
Thread: 200s keeps burning plugs
    junjun01 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    290
    After many plugs & carb cleaning & adjustments i got tire of this bike....sorry to say that now is on ebay.
    It burns a brand new plug in a matter of like 5 minutes running idle,sooner if you rev motor.
    -------I give up -------
    May 2003
    Shediac, New Brunswick
    1,126
    Quote Originally Posted by junjun01
    Does that plug happen to be BLACK? does it burn oil??
    Sounds like you are running WAY to RICH.
    Need to jet it leaner
    '84 Honda 200x
    slow restro
    Aug 2003
    290
    it dont burn oil,the plug is black,dry black like charcoal,i have try all kind of settings with the carb....still same
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    Mine did that because it had too big of a main jet, and now enough airflow. how big is your main jet?
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    Aug 2003
    290
    i have not idea how big its how can i find out that info?
    Ashland City, TN
    2,576
    Take out the jet that the yellow arrow is pointing too, there will be either a two-or-three digits number on there, that's what size your main jet is.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Aug 2003
    290
    Can the valves cause this ?, imean if they need adjustment can they make the bike do this?
    Eastern Long Island
    1,688
    Yes. My Big Red did the same thing. The ex. valve was way out and the intake was pretty far off too. My Clymer calls for 0.002 in. (or 0.05mm) for both valves with the motor cold. If you try to adjust them make sure the motor is at TDC.
    Lots O Trikes!!!!!
