Results 1 to 8 of 8
Thread: goki starter
    goki starter
    I received my goki starter i won off of ebay last night. the install was a breaze, it was easier because all the componites were assembled. i have to go today and get a battery and a battery cable and i should on the road. it is on the road but now it will have an electric start. this is on my 200S.
    i won the starter kit for $6 and some change. the guy also thru in a rear brake assembly and some other wire set up that through me off because i spent so much time trying to figure out what it went for but it was for something else.
    a big ol thanks goes out to johnny-aka ejc042. he took the time to fax me 20 pages of instructions for the stater that the guy did not have.
    84 200x, 83 200s, 2001 polaris scrambler 50, 79 jr 50 for sale, pocket bike
    May 2002
    Dublin, Georgia
    635
    Glad to hear you got it installed. Now we just need to get to gether to ride sometime.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    some time this summer we will get together for sure. i just need to get my new carb that i am buying from whiterider, i think that is his name.
    my 200x will run great untill the float bowl gets to full and floads out the cylinder. i just wait a minute and fire her back up and ride untill the next time. my wife sure likes to spray me with mud while i am trying to restart it.
    Us
    727
    chuck, what your describing sounds more like your float level is too low in your carb. if your carb flooded enough to stall the motor while its running, i dont think it would start again. but it your float level is too low, your bowl will empty without being re-filled quick enough, which would make it stall out, and the start up in a little bit. just my opinion, but you ride the machine and know it better than me. good luck
    Jun 2003
    South of Rochester, NY
    3,470
    YOu got a Goki starter kit for $6 ?
    Darn! He have one for a 350X?
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    ooops i ment to say $46 and some change, still a good deal.
    as far as the float goes, you maybe be right but i know i can not adjust my float seeing as it is all platic. i was assuming the float being to high, to low sounds good to me, i just wish i could adjust it.
    the other reason i was saying it was to high is because it will spray gas out some little vent tubes that face the air cleaner assembly, i was told and think that is becasue there is to much gas getting in there, but maybe i dont really know. i got a new one on the way.
    Us
    727
    your probably right then. good luck with it!
