Results 1 to 8 of 8
Thread: Heeeeeeeeelp Stripped Bolt What To Do???
    eh_tee_see's Avatar
    eh_tee_see is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Bristol Bay Alaska
    295
    ohhhhhhhhh woe is me... just got in my cobra for my 250sx and i get every bolt off except one stud!!! the bottom one, the nut wont come off the stud wont come it, the bolt is rustier than the titanic what to do??? i used vice grips and a can of WD 40 it did nothing!!!! what tips and tricks can i do besides take it and light it ablaze???
    The below sentence is TRUE.
    The above sentence is FALSE
    Mar 2003
    Australia
    1,919
    You should either try heating it up and using the vice grips again or drill it out and replace the stud/nut.
    Hope you get it off, it sure is a pain, i know from experience.
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    You need at least acetylene to heat it up a bit - I never get exhaust nuts or studs out without heat. I replaced my SX studs with stainless steel so hopefully it will never happen again. Good luck! Make sure to toss a 350X carb on that SX and throw away your airbox lid with that exhaust - say hello to nice power gains!!
    Us
    727
    maybe try a little pipe wrench with the heat if the vise grips don't work. good luck
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    there is a tool called a nut splitter,, maybe a rental place has one or your local napa ,,,, they work great and will not hurt the threads if you are careful,,,
    JoeSuzuki's Avatar
    JoeSuzuki is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    Ontario Canada
    172
    Drill it out, then rethread.
    Still learning how to use and abuse my toys.
    KASEY's Avatar
    4,250
    if i read it right he has not twisted it off yet,,, so there is no need to do any drilling yet,,,,, so be careful ,,
    JoeSuzuki's Avatar
    Jan 2004
    Ontario Canada
    172
    well if it aint out or broken yet, try that: let it sit in lemon juice (put it on a rag and slam it on) over night, then the next mornin try with a small impact, and if you get some space, try and keep some pressur towards you with a small prybar while you unscrewing. (set your impact to the slowest speed and strenght)
